Question about Dishwashers
Why is my quick connect leaking? - Dishwashers
    Sergeant:
    Champion:
  • 338 Answers
The bearings are going bad.. you will need to replace it.
Posted on Dec 22, 2008
My 20 gallon campbell hausfeld wont hold air.what could be the problem
Joe:
There is an air leak somewhere in either the tank connections or the hose connections. Look at the tank and find the tube that runs from the top of the compressor to the tank (usually a brass line). grab a spray bottle and fill it with a soapy solution (dish washing soap and water is fine). Disconnect the rubber air hose from the tank (at the quick disconnect) and start the compressor. Spray the dishwashing solution on the brass line end fittings at the compressor head and the tank connection, and the quick disconnect fitting and where the quick disconnect connects to the air tank. If you see bubbles being blown, that is where your leak is. Also connect the hose to the tank and check your hose for leaks with the soapy solution. Once you find where the leak is, you can tighten the fitting or replace the faulty gasket or hose.
May 25, 2014 | Air Tools & Compressors
Kitchenaid superba leaking icemaker at quick connect
Go to Home Depot and get 1/4 Inch brass fittings from the plumbing section they will work better.
Nov 09, 2013 | KitchenAid Refrigerators
Fuel leak quick connector leak
Seeping like a connection at the quick disconnect is loose on one of the fittings? Or leaks alot like not connected all the way and a fuel injected Harley wont start? Or leaks alot like the quick connect fitting is broken internaly or has dirt in it?
Oct 11, 2013 | Harley Davidson Motorcycles
Stapler leaks air when the tool is connected
It is probably coming from the air hose connection itself. The cheaper ones are good for this. If you buy good quality quick connects they wont leak.
Jan 29, 2011 | Garden
Ashfield f-049-yw1k quick connect "center connector" fitting leaks. Also how is the fitting removed?
Here is a link to the Prince Pfister web site, and your specific model. I'm not sure what you mean by quick connect as this faucet doesn't appear to have any quick connect. Note two links one for parts list and the other for install manual
http://www.pricepfister.com/product_catalog/product_detail.aspx?id=107589#tab:1
Jun 15, 2010 | Plumbing
How do I fix a leak at the quick connect and the control body outlet tube?
I have the exact same problem. I just installed the unit yesterday and it does not leak until you use the sprayer. The sprayer leaks at the quick connect fitting at the base. As soon as I saw that new connection type I cringed. I may have to contact Pfister to see if they have any suggestions. I will be beyond ticked if I have to remove/reinstall a whole unit again.
Jan 02, 2010 | Price Pfister Marielle Kitchen Faucet with...
Oil leak
common oil leak on those vehicles is the "quick connects" where the oil lines go into the oil cooler (what i believe you are calling the "doble") replace the o-rings on the quick connects for the lines
Oct 05, 2008 | 1999 GMC Suburban
Water leak on manifold of 1996 susurban. looks like hydraulic line connected but suspect it might be rear heater hose that is leaking . any ideas?
I had this problem with my 1998 suburban.......there is a quick connect that goes into the  top of the engine close to the water pump.......the hose will come off without any tools....the quick connect screws into the top of the engine.....in fact my was so screwed up it busted off in the engine and I had to use an easy out to remove it.........
I went to O'reillys and they showed me what was leaking...... when its just leaking a little it hits the manifold and evaporates....so you never see any water...
Aug 13, 2008 | 2004 Chevrolet Suburban
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
