Question about Toshiba 57H81 57" Rear Projection Television
Fuzzy/ distorted tv pic
I have a toshiba 57H81, the menu picture is clear but the tv picture is all fuzzy and distorted. What can that ba and how can i fix it? also I need the service manual.
  • Toshiba Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
fuzzy/ distorted tv pic - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 30, 2010
I'm getting a double image of everything on the screen in a hazy blue colour. I tried configuring the colour within the menu but the cross simply won't line up. touch focus seems to work with the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 11, 2011 | Toshiba 57H81 57" Rear Projection...
I want to clean inside the screen & picture tube lamps but do not know how to open tv my tv is toshiba 57h81, picture is little dusty
just take out all screws, use compressed air, be careful, etc, screw back on. some models require u to remove the speakers grill or something by pulling them off to reveal the screws
here these pics may help you a lot (scroll down a little, and refresh if u see no pics, some guy named pittdog1 posted them)
Mar 07, 2011 | Toshiba Televison & Video
Got used Toshiba 57H81 and picture is fuzzy like 3D. Touch focus error message shows.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Toshiba 57H81 57" Rear Projection...
Dark, fuzzy picture
The fluid in the CRT bulbs is most likely cloudy. Check the blue to see if fluid is clear. If fluid is clear, then likely your flyback transformer is failing. I assume you already check the brightness and contrast settings on the tv.
Feb 18, 2011 | Toshiba 57H81 57" Rear Projection...
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Jul 06, 2009 | Toshiba 57H81 57" Rear Projection...
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
57H81 projection tv has very wiggly picture.
This is the Hyper Module that needs repaired. There are several small sm caps that dry out in this model. It's the module standing up to the right covered by a can as we call it. I really don.t recommend you trying to repair it. One slip and that module is done and you can't by a new or rebuilt one anymore. Please let a repair center look at it and do the work. You won't regret it.
Mar 08, 2009 | Toshiba 57H81 57" Rear Projection...
My Toshiba 57H81 has a 'jittery' picture.
I have the same prob need to change the resistors as a first resolution. there should be 5 of them, if you dont soon and i mean soon you could cause the skt to go bad and have to start over in your repair
Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Dec 23, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57HX81 57 in. Rear Projection
Im guessing the the convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
2,628 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
