Question about GE Spacemaker JVM1640SJ Microwave Oven
No heat Light fan clock all working. Sounds like food is cooking but cold when removed.
  • Anonymous Jan 27, 2009
    clock,fan,sound, all seems good but no heat.
  • Robert Artiaco May 11, 2010
    do u have a multi meter to do some testing??
  • 21 Answers
Heating element stopped working
easiest thing is to get a new microwave
Posted on Dec 23, 2008
How can I get my microwave to actually heat when everything else (cook time, power level, clock, etc., are set and seem to be running?
Sounds like the MW Emitter is not working or the wave guide is disconnected. If it is the wave guide then you can fix it yourself if you take the rear cover off. It is the pipe, which in cross section is quite rectangle shaped with rounded corners. It should be connected to the emitter at one end and the opaque guide cover at the other with no breaks. If the emitter is faulty then seek professional help.
Oct 19, 2014 | Hamilton Beach 1.1 cu ft Digital Microwave...
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave light and clock work but no heat
Could be one of the three door switches. If the fan turns on when cooking and no heat then the magnetron is bad. Most problems are the switches
Feb 20, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Ihave a Jenn-Air JMV8196 microwave oven. The clock works,the fan works and the light works. Not sure why the microwave will not come on to cook. Help?
The problem is caused by one of three things, the magnetron "heats food" the high voltage diode "sometimes shorts" or the high voltage capacitor " shorts"
Mar 10, 2012 | Jenn-Air JMV8196 Microwave Oven
Hi my microwave is not heating food
There is a tube I believe, in microwaves that produce the waves that heat the food. A fan usually disperses the waves to make the heating more even, rather than cooking one spot and leaving the rest cold or frozen.
Replace it. Cheaper than the fix, unless it is only the fan. But you still have to take it in, and there will be a service charge on top of the parts replacement.
Jan 07, 2011 | Samsung SMH7174BC Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
My microwave want heat up it has been getting moisture all in it when it was cooking clock works turntable works light works it does not heat up it smells like it is a defect
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Apr 23, 2009 | Kenmore 62109 Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
95 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
