Question about KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Kitchen Range
Kitchenaid KDRP463LSS - No electricity to oven
The oven was working one minute, then just lost all electricity. The display went dead, oven lights won't come on, and heating elements no longer heat. It's as if someone turned off the circuit. All wiring, circuits, and breakers have been checked, the unit is getting a full 240 volts AC. The electric ignitors for the stovetop burners are working, but nothing down in the oven. Anyone know what the problem may be??
    Scholar:
  • 127 Answers
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
Kitchenaid KDRP463LSS - No electricity to oven - partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Posted on Dec 23, 2008
Need part number for BBQ option to replace griddle
You will need the model number & serial number which may be on the back of the cooker on behind the plate under the oven door, then contact the manufacturer or agent. Reece HVAC are also a very good source to obtain parts from.
May 07, 2014 | KitchenAid KDRP463LSS Dual Fuel (Electric...
The display and buttons are dead, no display or oven lights but electric starter still works on stove top
find the breaker for the stove and turn it off for 2 minutes then back on, if that does not work look on back of stove in area of controles for a small reset button, some time they are hidden just inside a small hole
Jan 09, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Display panel stopped working
Nov 9, 2009 ... I could thump it with my fist, not hard, just a light thump, and it would come back on ... Problem with KitchenAid KESC307 Electric Kitchen Range ... the ribbon cables and the panel can be removed to a convenient work surface. www.fixya.com/support/t3391463-kitchenaid_range_kesc307hbt8_display www.fixya.com/support/t3391463-kitchenaid_range_kesc307hbt8_display
Just checked this site and it has an answer to your problem. Very complicated, but I am sure you will be able to follow it
Feb 15, 2012 | KitchenAid KESC307 Electric Kitchen Range
KEMC308 has frozen, unusual looking display info. Nothing works.
Try unplugging it or flipping the breaker to the oven. Leave the power off to it for a minute, then turn it back on.
Mar 27, 2009 | KitchenAid KEMC308 Electric Double Oven
Built in Convection Microwave Oven KBHS109SSS
no reset buton persay but fuses and control boards. MICROWAVES emit and store HIGH VOLTAGE nad should only be access and repaired by trained proffessionals. NO JOKE HIGH VOLTAGE. like your DEAD VOLTAGE
Nov 20, 2008 | KitchenAid Architect Series KEMC308KSS...
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Open Questions:
See all KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Questions
KitchenAid KDRP463LSS Dual Fuel (Electric and Gas) Kitchen Range Logo
516 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
