Question about Desa International ReddyHeater® R115DT Utility
The heater shuts off tripping the reset- motor/fan ***'y is froze
I have an RU motor P/N 097134-02 (1/5 H.P., 120V, 60HZ, 4.9amp, 3450 RPM) from a Model R110 Reddy Heater, Serial #5231026. Where can I buy a replacement motor?
I have 50 various new motors including this one. 419-834-1284 ohio
Posted on Jan 09, 2011
  • 232 Answers
097134-02 try Reddy Parts
Posted on Dec 23, 2008
Trying to get info on both capacitors.GE motor 115volt 3450rpm part# MO 9045
the rating for the capacitors is printed /imprinted on the capacitors
take them along with the information you have given to a electrical motor rewind shop and they will match them up
Apr 19, 2015 | DeVilbiss Air Tools & Compressors
Leak from motor
We need the make and model of the pump (ex. Hayward Super ll, Pentair WhisperFlow), and where the leak is. Your motor will fit a lot of different pumps. Thanks.
Feb 23, 2014 | AO Smith Pool & Spa
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Dayton 100K btu kerosene salamander heater - been running fine until last night. Unit is about 15 yrs. old. Ran for about an hour , then tripped out. I reset it and it would run for 1 - 2 min. and trip...
On that motor there should be a thermal overload to shut motor off in the event that it gets to hot. There also should be a start capacitor and if it is getting weak that could account for the unit tripping the breaker if it is trying to draw to many amps on start up. I would start by replacing the capacitor with plan to install new motor soon.
You may be able to extend the life of your motor some by giving it and fan a good cleaning, Good luck and thank you.
Jan 18, 2011 | Dayton (3E386) Heater
Alaska stoker II blower repair
Try W.W. Grainger. You can try calling them; however, often times it is better to take the motor directly in to them to have them match something up.
Hope this helps and good luck!
Feb 21, 2010 | Heating & Cooling
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
3450rpm motor
MOTOR SHOULD HAVE A RESET BUTTON.
IF U CAN FIND IT, HOLD IT IN-IF MOTOR RUNS
RESET MAY HAVE TO BE REPLACED.MAKE
SURE MOTOR DOES NOT OVERHEAT UNDER
LOAD-THIS MIGHT BE THE PROBLEM.
Jun 21, 2009 | Leeson Reversible Electric Motor 1/2 Hp,...
Motor & pulley
It would take 6" pully w/ a 2.25" which would not fit on that machine, no room for the 6". Replace with the same RPM motor is the proper way, unless you simply want a slower speed sander, duh! You cannot change the motor rpm without a defenant power issue, if you change the rpm your sander will power out, sorry?
Mar 30, 2009 | Tools & Hardware - Others
Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Mar 16, 2009 | Mr. Heater Natural Gas Garage Heater -...
Desa International ReddyHeater® R115DT Utility Logo
655 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
