Question about Electrolux ERN2820 Bottom Freezer Refrigerator
Electrolux ERN 2821 not working,making humming noise when on
Not cooling or freezing
  • Electrolux Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Posted on Oct 06, 2010
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
Electrolux ewf 1470 not spinning no error message
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
Oct 07, 2012 | Electrolux EW1000i Front Load Washer
Electrolux fridge freezer not cooling or freezing
If the compressor is not coming on then first check the start capacitor and if this is good then check that the contactor or relay is working properly Hopefully its one of these if not it may be the thermistat but probably the compressor has siezed.. I know this sounds wierd but if u can gain acces to it tap it with hammer this will some times unsieze them
Jul 24, 2012 | Refrigerators
Both fridge / freezer are not cooling down. It sounds like the motors are not working.But there is power going in. Also there is a small humming engine noise.
Are you sure the humming noise is from the compressor motor being locked up? It is normal for the compressor motor to make a humming noise when it runs. Make sure the fan in the freezer is also running while the compressor motor is running and replace it if necessary.
You need to defrost the coils in the back of your freezer. You can do this the slow, easy way by simply unplugging the refrigerator for 24 hours. Leave the doors open to ensure everything has the chance to melt.
The fast way to defrost the coils is to turn off the refrigerator and remove the rear panel from the freezer compartment. You will see the evaporator coil completely frozen with ice. Thaw the ice with a hair dryer and make sure you thaw the drain at the bottom of the back wall as well.
When you turn replace the freezer panel and turn the refrigerator back on, it will get cold again.
Mar 06, 2010 | Electrolux Refrigerators
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Refridgerator is not cooling or freezing
If the compressor comes on, then it is most likely working, unless it makes a loud humming noise. However, if it makes a clicking noise, it could have a bad relay. If the compressor gets too hot, it will shut itself off on overload until it's cool enough to run again, which is usually long enough to defrost your food.
You may have a problem in your sealed system. If this is the case, there may be a refrigerant leak somewhere. If this is the case, you should have a technician come out. Your sealed system should be covered under warranty if your refrigerator is under 5 years old.
Please let me know if you have any other questions about this.
Mar 10, 2008 | Refrigerators
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Electrolux ERN2820 Bottom Freezer Refrigerator Logo
936 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
