Question about LG Televison & Video
Restore region Code.
LG DVD Player/Video Cassette Recorder.  Code 314159 was entered to enable playing NTSC  DVD Now don't know how to restore to Region 4.
SOURCE: Region Codes
I have the MAGNAVOX BDP170MW8 as well and would love the help finding the UNLOCK REGIONS CODE. please assist. thx..
Posted on Dec 28, 2007
  • 376 Answers
SOURCE: region free unlocking code for LG RH2T80 DVD Recorder
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
Posted on Oct 19, 2008
SOURCE: Other Region codes for Samsung DVD 1080PK
Region code hack posted by anindo_roy, January 09 2009:
I bought a Samsung DVD player 1080PK in Bangalore recently (Jan 2009) and initially it was coded only for region 5 (India). I went through the following steps (which were told to me by a Samsung technician) to make it region free. This steps match closely to the one posed by another viewer so I have retained the same format.
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear.
6) Locate the Repeat A-B button on the remote, which in my case was ‘9’
6) Now type the code that applies for your region (R5 (India) is 53814) followed by 9 (Repeat A-B button) and then press the Enter button. So enter 538149 and then Enter. A last few digits ‘4’ and '9' may briefly show up at the top left corner.
8) Power off the player, and turn it on again. You'll have a multi region player
Region Code for the 1080PK hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked for me after a couple of tries.
Posted on Jan 26, 2009
SOURCE: How can I unlock unlock PANASONIC BLU RAY Recorder
how to unlock panasonic DMR-BW850
Posted on Apr 29, 2010
hi its a bit late but someone might benefit from this. Make sure that u CLOSE dvd cover.
To multizone:
Make sure that there is no disk in. CLOSE dvd cover. Press power on on remote. if dvd goes into standby press power again. unit will be searching for a disk. as soon as player says NO DISK (heres where u have to guess since the bloody thing is closed) press PAUSE then press 314159 in quickly. Now open and voila the screen will read current region press 0 then PAUSE and finally Power key. it worked for me after trying a billion times the 314159 thing.
Posted on May 19, 2010
How do I set to play all regions on LG RH1777 DVD Recorder?
enter "setup" from the remote
Scroll down to the lock symbol
Press the "0" button 7 times
You'll get a confirmation message and then your DVD player is region free :-)
Feb 18, 2015 | LG RH1777 DVD Recorder
Hi i have a lg bg550 blueray dvd and i have just got a region1 disc is there a unlocking code for this model so i can play region1 and region 2 discs regards **** towner
Could not locate this model but this may help:
Power up the Player, press pause;
Type in 314159 on your Remote Control's Keypad;
This should bring up the Region Selection Screen;
Select the Region (1-6) that you wish to view on your Remote Control's Keypad, sit back, and enjoy ;-)
Two important features with this player.
Firstly, in addition to the first hack listed above, instead of choosing a Region 1 through 6, you can choose to set it Region 0, or region free. This means you will not need to change it every time you put in a disc of differing regions.
Also, if your TV is not capable of both NTSC and PAL playback, you can adjust the format of the DVD player signal by flicking the System Select switch on the rear of the player. Without changing this, the region free hacks listed above may not display correctly if you are using an older TV
To enable VCD, it works for this model as other LG players:
1. Power on the player with no disc in the drive.
2. Press Pause on the remote control.
3. Using the remote control, key in the following: 1, 4, 7, 2 (the
characters 01 47 should appear on the display) [If your player is a non UK
model, this number will probably be different - don't worry]
4. Press the UP arrow three times (the characters 04 Fd should appear on the
[This number may be different depending on the configuration of your
specific model - don't worry]
5. Press Program, 6, Program, 5 (the characters 04 FE should now be
6. Press Enter (the display should flash briefly).
7. Press Return.
8. Power the player off and then back on.
9. Play a VCD!
Jul 25, 2011 | LG BD550 Blu-Ray Player
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
I have an LG DVD Player/Video Cassette Recorder V271 and I want 2 play an American DVD on you know the unlock code please?
Turn on the unit and open the tray. Press 0000 on the remote to access the DVD region code selector.
Change the EEPRom code to 0 to remove the region lock.
Press Pause to exit the screen and your LG V271 should now be region free.
Sep 13, 2009 | LG V271 DVD Player/VCR
Region code error for my LG RC388 DVD/VCR player & recorder
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Please rate our Free help to keep the service online ++++
Aug 30, 2009 | Televison & Video
DR 389 DVD player
Try one of these:
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select region code as '0'
2) Press PAUSE
3) Key in 314159
7) Power off player
Apr 22, 2009 | Televison & Video
Need unlock code for LG V774W
I just tried this on LGV774W and it worked :))
To make this player region free (or change the region), do the following:
* Ensure that there is no disc in the player (ie: "no disc" is displayed).
* Press PAUSE
* Enter 314159
* Enter the region code (0 for region free, or 1-6).
* Press PAUSE
* Turn the player off for a few seconds.
* Turn the player back on
* Voila! You beauty!!
Jan 13, 2009 | LG XBR446 DVD Recorder/VCR
DVD player area code.
1. turn it on.
2. open disc tray
3. pause and press 314159
4. the player shows the actual region and a field to enter a new one.
5. enter new region. (0 for region free)
6. pause
7. Play
Aug 25, 2008 | LG Electronic LRA516 DVD Recorder
Open Questions:
I have a LG 50 LCD TV Model: 50LN5700-UH that has a black screen. There are a couple of things I have tested and replaced. First off there is audio but just a black screen. I turned off the lights and looked for signs of back lights. When I did this there were no visible signs of lights. In addition, I did the flashlight test. Which showed visible signs of lettering on the screen with the flashlight. Which if I understand correctly it may determine that the T-Con board is functional. I ordered additional LCD's from Shop Jimmy and replaced the bad sticks. About half were replaced. I reassembled the TV and I am still getting no video, but I still have audio. However, this time all the LCD's are functioning so now the screen is still more grey than black because of the working LCD's I replaced. What voltages and at what points should I be testing to narrow down the problem, or what other problem-solving technique should I be testing? One other thing I should mention is there no visible signs of swollen capacitors or any signs of burn marks. I am 99% sure I connected all of the cabling up correctly, not 100% since this was my first attempt but I am a little less confident I put the filters in the correct way. I had the TV disassembled while I was waiting on the LCD's to ship and when I re-assembled I was less confident if I picked up all 3 or 4 filters and set them down, or if I make have flipped the filters to keep the circuit board on the front cover from being damaged. Hope that make since.
Mar 16, 2018 | LG Televison & Video
Televison & Video Logo
29 people viewed this question
Computer Repairing
Computer Repairing
