Question about E-Machines T6216 (827103077834) PC Desktop
Installed new motherboard now LAN not found? How to fix
Needed new motherboard father in law installed now we do not have access to internet. if looking at the internet option there is no LAN on computer anylonger? How do we install or fix problem ad a LAN to computer?
  • dandi91 Dec 23, 2008
    O.k. thanks for the reply. I will find out what if it has an onboard lan and will go from there.........
    I guess the motherboard does have an onboard LAN. We'll go fom there.............
Hello i m ravishankar from hubl 9611738396
so u installed a new mother board but u cant access the network
please chek out u r lan driver is confertable or not and check ur mother board RJ45 connector some times that is internally shotted.
then install fresh o s to u r pc. try it
than check u r network cable or modem and cable .
Posted on Apr 11, 2009
    President:
  • 1,179 Answers
Does the new motherboard have onboard LAN? If not you will need to install an ethernet or wireless card depending on your setup. Hope this helps.
Posted on Dec 22, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 23, 2008
    If it has onboard LAN then all you should need is the driver. Hope this helps.
I don't have internet access on my new X58A-GD45 motherboard. I just tested the ethernet cable and it successfully delivered internet to another computer in my house, so it's just this new...
- check if you have a link light on the NIC port
- also check if there is a network adapter driver installed under device manager
- then click start type run and type cmd
- under CMD, type ipconfig and check if you have a valid IP
ex. 192.168.1.1 not valid is the IP that start with 169
Jun 25, 2011 | MSI X58A-GD45 LGA 1366 Intel X58 SATA...
Network adaptor can not be installed
Hi Good day!! download your LAN here: http://support.asus.com/download/download.aspx?SLanguage=en-us in the input model search, upper left of your screen. enter your P5KPL-AM SE and then search, after that your drivers will appear choose Lan and then download it. then install your lan. hope it works now...
REGARDS
JR
Oct 18, 2010 | ASUS P5KPL-AM SE Motherboard
Hello my father in law gave us a Belkin F5D8230-4
You need to install the serial number in your computer off of the router, clcik on diagnose and when it comes up with enter pass phrase input your serial number ans you should be connected. Hope this helps and thanks for using fix-ya.
Jun 21, 2010 | Computers & Internet
Can not locate net work adapter
Possible cause:
The hard drive contains all the necessary drivers that makes the computer function and that includes Internet connection. When you installed the operating system and all other software it does not mean you installed the driver for the motherboard which contains the drivers for the LAN.
Solution:
Run the drivers CD that came with the motherboard. If you don't have the CD. contact the PC manufacturer for the driver CD. Otherwise, you can purchase an add on NIC(network interface card).
Mar 20, 2010 | Computers & Internet
After formatting i cannot access the internet, when i check the LAN i don't see a blinking light i try to look for a motherboard driver for my motherboard with model a690g-m2 but i found nothing.
Here is a link to the motherboard drivers, if u havent installed any, i suggest u download them all depending on ur OS and running them.
Nov 01, 2009 | Computers & Internet
NTLDS missing when installing windows 7
Before tring to install Windows 7 I suggest you download (or your in law) from Microsoft a utility program that detects your hardware and tells you whether the system will support this RC version of Windows. Download "Windows6.0-KB947821-v4-x86 Update Readiness.msi" and run it on the system prior to installation. If your system is already damaged, install a base WinXP OS on it and try it. Good luck!
Aug 16, 2009 | Microsoft Computers & Internet
I cant access the internet.
If you have the cable plugged to your modem, connect the cable to the pc and then restart the modem.
Also try a reboot and make sure you don't have windows firewall on nor static IP.
Cheers
Jun 22, 2009 | Asrock ConRoe1333-D667 Motherboard
Network Card
Yes the network card is the same ethernet card. If your intel pro/100 is onboard try to re install the driver from the motherboard drvier. Check also in the manager device it the network device have a complex to the other device. Follow this, Click START then RUN type DEVMMGMT.MSC then enter check if the network adapter have a yellow question mark. If you found the network adapter right click and uninstall it.and click the ACTION and click SCAN FOR HARDWARE CHANGES. After the installation finished try to connect to the internet. If still the same even you input the correct ip in the network configuration. Buy a new LAN card it's not expensive, because usually the onboard lan is easy to damage or not working properly you can installed and configured it but you cannot connect to the internet.
Apr 15, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
E-Machines T6216 (827103077834) PC Desktop Logo
583 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
