RIM BlackBerry® Curve? 8330 Cellular Phone
Problem for RIM BlackBerry® Curve? 8330 Cellular Phone
Buttons on the curve not responding.
By Akio K S on Dec 22, 2008
Every button I press including the on and off button won't respond. But I know it can turn on because when I replace the battery it takes me to the main menu. The only problem I can think of is that I held the blackberry when my hands were wet. Ever since then it hasn't worked. I have the same problem. What is up with this?! It seems as though everything is working, except the buttons do not respond when pressed. I can receive incoming calls, but the "send" button won't register in order for me to answer the calls. I have restarted the phone several times, with no success. My provider is Verizon.
I would be thrilled if there was an easy solution to this...highly unlikely though, huh?
Same Problem
Apr 25, 2009
-   Same. I'm irate that I am spending this month monthly for a "better" phone when, in fact, my RAZR was a completely fine choice. I am sitting here helpless like the rest of you.
BB, I don't get how you can sleep at night knowing that all of us can't because you didn't design your phone well enough.
-   Guest
Apr 14, 2009
-   AHHH i have the same problem! the ball moves to the sides, but nothing else works! its still flashing at me because i have a text, and it receives my other texts, but i cant even read them! it is so annoying! i have this phone and verizon, too!  -   Guest
Apr 11, 2009
-   I had the exact same problem you just described - I could have written it myself. It happened after I picked up my phone and read a text message while I was in the shower. I was careful not to get the phone wet so I didn't think this was the cause but maybe it was, since my fingers were obviously wet when handling it. I brought my Blackberry to Tmobile where I purchased it, and they replaced it for me (it was still under warranty). I made sure to transfer my photos and videos from my phone to my computer before I made the switch to the new phone. -   TS1215
Mar 25, 2009
-   same problem it works sometimes but not others, was not that long ago when i fist got it wet but it seems like it doesn't work on rainy/humid days and when the buttons do work i can text just fine but when i answer a call or make a call i cant hear anything and the people I'm trying to talk to cant hear me -   lukehoenes
Mar 23, 2009
-   I have exactly the same problem with my BB Curve! Help! -   haltomar
Best Solution
posted on Mar 19, 2009
Very Helpful)
yarrow911
Rank: Apprentice
Rating: 100%, 1 votes
sorry i acually had to take mine in and have them give me a new one same problem , i went out dancing and put phone in my boot , and well it didnt make it to next day . try holing down the botton on top of phone for few seconds . if that dont work sorry getting a new one . since the bottons dont work you loose all contacts . everything it sucked .
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 01, 2009
Very Helpful)
Bajanguru
Rank: Wiz
Rating: 82%, 3791 votes
akio - the easiest solution will be able to take the phone to a mobile service center and have them service the phones keyboard for you to make it work again.
jason + guest - the phone needs to be fully service then take the phone to a mobile repair center and have that done.
Was this helpful?
Yes
No
Solution #3
posted on Apr 03, 2009
Helpful)
natew65
Rank: Apprentice
Rating: 92%, 3 votes
had the same problem my curves key pad did not respond at all after researching and investigating i found this is apperantly a very common problem and found only one place that had an answere most do not know about the curves soft reset ability in other words reseting the phone without removing the battery this opperation can be performed by simultaniously holding down three keys the Alt,theshift or aA up arrow ,and the del buttons all together u may have to try it a few times for it to work and once it has your red power light at the top will flash once the screen lights up again repeat the process five or six times to ensure it is reloading all info stored and lastley if a soft reset does not work attempt to do a hard reset by removing the battery while ur power is on still but leave it out longer than 30 seconds i left my battery out for about 5 min then reinstalled it and now all is well in bb world once more remeber your bb is basic but still a pc none the less and as such it is a good practice to do a reset periodically to ensure the quallity of the bb functioning best wishes and i hope this is able to help you if not whatever u do don't attempt to take the bb apart unless u r trained pro because it should have a one year warranty on it and any thing u attempt to do on ur own will void the warranty
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Jun 17, 2009
Somewhat Helpful)
ipodtuneu271
Rank: Guru
Rating: 90%, 18 votes
Did it get wet at all? there is an area under the track ball that goes bad if it get's wet. Cleaning that area with a brush can sometime get it up and running again. try to remove the trackball and clean the area below it if necessary. There is a Blackberry Repair Guide that shows how to open a Blackberry and remove the track ball yourself.
Was this helpful?
Yes
No
Solution #5
posted on Jan 18, 2009
Somewhat Helpful)
kylesiis
Rank: Apprentice
Rating: 75%, 1 votes
take ur ball out and clean it
Was this helpful?
Yes
No
Popular Solutions for RIM BlackBerry® Curve? 8330
Questions and Unsolved Problems for RIM BlackBerry® Curve? 8330
Do you recommend RIM BlackBerry® Curve? 8330 Cellular Phone?
Answer
Answer
I had a friend send me a video useing his blackberry to both record the video and sent the video to... (More)
Answer
When I change my signature on my blackberry Curve 8830, and send an e-mail to myself for testing (or... (More)
Answer
black berry wont play videos that i recorded on it. media players states error message
Answer
when i put in my email address on my blackberry it wont let me use it i can only use my phone number
Answer
My black berry 8520 says i have an unread message but i deleted all of my messages and its still... (More)
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 16, 2009
Phone turns on and I can scroll up or down but, the phone doesn't respond to key pad or scroll ball when hitting select.
Comment by Guest, posted on Jan 24, 2009
MY BLACKBERRY 8330 HAS THE SAME PROBLEM. ONE DAY IT WORKS JUST FINE, THEN ALL OF A SUDDEN MY BUTTONS DOES NOT WORK. IAM ALSO W/ VERIZON.
Comment by Guest, posted on Jan 12, 2009
I have the same problem. I was hiking and had my Verizon BB Curve in an inside pocket away from the elements. However some condensation (sweat) got on the screen and it quit working. I can receive calls, emails, texts; but I can not respond to them at all or answer the calls. Very frustrating since the BB is so sensitive.
Comment by Guest, posted on Jan 06, 2009
My curve has the same issue. Verizon is sending me a replacement again. This is the 3rd time this has happened to me.
Comment by jasond530, posted on Dec 28, 2008
same thing. got it wet and can't do anything but watch it tell me i have messages and watch it tell me i have a call.
Comment by Guest, posted on Dec 25, 2008
same problem since putting my phone in my pocket while snow skiing. caused condensation to appear under screen. receiving calls and texts but cannot respond due to inoperable keyboard.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular... Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
