Question about Epson Perfection 1260 Photo Flatbed Scanner
Scanner coloring doc.
I scanned a b/w drawing and also a colored drawing, both scanned saturated in red and green. what's the deal and can i adjust something?
    Sergeant:
  • 287 Answers
In your printer menu there should be a option for cleaning the printer heads. if not you need to remove the cartrages and clean yourself with rubbing alcohol. also clean off the cartrages also.this should get rid of the saturation problem.let me know if this helped.
Posted on Dec 25, 2008
The scanner, which used to be fast, now runs extremely slow. It takes about a minute and a half for the Dell AIO Center software to load, nearly 3 minutes to preview, and 2 minutes to scan. So just to scan...
Scanners speed is influenced by the quality chosen in document productions. Selecting impressionful color saturation requires time to produce results. Use the menu buttons on the scanner to select least saturated color pixels.
Feb 02, 2011 | Dell 968w Printer
I am seeing blue lines on the document after scanning
reduce the saturation levels for the blue color if not all the colors. also try reducing the resolution settings for the scans
Sep 07, 2010 | Epson Perfection 1670 Flatbed Scanner
When we scan a drawing, we get a green background.
Try scanning with different software, such as MSOffice Photo Editor. It could be the scanner TWAIN settings or the app that you are scanning with.
Aug 31, 2009 | Hawking Contex HAWK-EYE Cx Scanner
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Colorize drawings on Canon Lide 25 scanner?
Open Jpeg in a paint program or photoshop, add color and save as *.jpeg, so you keep the original
May 03, 2009 | Office Equipment & Supplies
Bad contrast with scanner
Last things first: NO USER SERVICEABLE PARTS INSIDE.
That's the way HP does things. There are no rheostats or pots to adjust. It's all done electronically now, with chips and things.
You never said how it does with color or greyscale photos or drawings.
As for the RGB=(64,64,64), that's about right for the scan picture settings and the mixed (text and graphics) setting, and is particularly true for color picture settings. Have you tried using the setting for drawings (or line art), specifically greyscale drawings? Usually the greyscale lineart or drawing setting will render black text. You might also try scanning with the settings set for Text. If the greyscale drawing settings or greyscale text settings do not produce black text, try reinstalling your software and drivers.
If the contrast stays the same for all settings after reinstalling the software and drivers, and if it doesn't scan color and greyscale pictures correctly, then it sounds like your scanner is going bad.
As for the scans you've already done, you can darken the text by taking it into a photo editor, such as Paint Shop Pro or Photo Shop, and adjust the contrast and brightness to get the effect you desire.
Apr 18, 2009 | HP Scanjet 8250 Flatbed Scanner
When i scan a photo it comes out a solaesied green.Is it time to buy a new scanner.
it seems like the ccd scanning engine is having problems now if the scanned doc is always green in color then yes it is time to buy a new scanner, i think HP scanners are better , and also mustek its an economical brand as well but look for vista and windows 7 support in it
pls rate me generously if u like my response
Mar 06, 2009 | Canon CanoScan D1230U Flatbed Scanner
Out of Focus Scans
You have some limited color adjustment settings in ScanGear that you can play around with. I would recommend recalibrating the scanner. This is done in ScanGear Advanced mode under Image Settings.
May 28, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Redish/Pinks color to scans.
You need to reset your scanner's color management settings to default..
Which utilty software r u using?Arcsoft Photostudio?If yes go to Edit ->preferences
Set RGB settings to the same level(adjust the slider next to red)
If it doesnt work or u r not using arcsoft..post back..
Nov 04, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Epson Perfection 1260 Photo Flatbed Scanner Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
