Question about Gateway 2520915 Keyboard
I was cleaning the keyboard on my Gateway model mx6124 and pressed a combination that rotated my display 90 degrees. How do I turn it back?
  • 15,935 Answers
Not a key combo--it's a display properties setting. Look for an icon for your
video card
in the lower right corner Notification Area. Right click on it to
adjust. If you don't have the icon, go to Display Properties, Settings,
Advanced, Rotation.
Or try control-alt and one of the arrow keys at the same time.
Posted on Dec 22, 2008
Why does the screen keep rolling in circles
I'm assuming it rotates 90 degrees at each 'roll'? Try cleaning the keyboard. Usually a combination of CTRL and another key is the shortcut for rotating displays, and some of your keys might be sticking.
Jun 13, 2013 | Computers & Internet
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
HP 1740 screen image rotated 90 degrees - how to move back
On most video cards the key combinations of ctrl+alt+left arrow, ctrl+alt+right arrow, ctrl+alt+up arrow or ctrl+alt+down arrow will allow you to rotate the screen display in any direction. Each key combination will rotate the screen in the direction of the key press.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 23, 2010 | HP Pavilion F1703 17" LCD Monitor
Desktop has rotated 90 degrees
keep pressing ctrl&alt and press upper arrow key
Apr 05, 2010 | HP w1907 LCD Monitor
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
My screen is upside down and my mouse right and left side are reversed, how can I change it back?
On my shuttle, there is a combination of button to turn the screen 90 degrees to the left or right. Something Like CTRL + ALT + Up Arrow or CTRL + SHIFT + arrow or ALT + SHIFT + Arrow , to rotate to different angle , also there are Viewing options in your display drivers. In the ATI control panel, there is a tab rotation to rotate the desktop 90 degrees to the right or left or 180 °
Try this.
Oct 12, 2009 | Dell Optiplex 755 Ultra Small Form Factor...
Rotating screen display
click again until screen is right. then open mouse config and turn off that button or change it's function.
Jul 01, 2008 | Logitech 9311570403 Mouse
SCREEN TURNED TO LEFT WHEN I HIT KEYBOARD WITH BOOK COVER
1. If you right click on the desktop and look at graphics properties, or something similar to that, then you should get a menu for your display adapter control panel. Usually the screen rotation is right there. Sometimes it's as easy as a CTRL + arrow key combination, but I'd rather see you adjust it from a menu.
2. Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees (If that doesn’t work, try Ctrl-Shift-R)
3. If you have the intel video chipset, I believe pressing CTRL+ALT+ one of the arrow keys should fix your problem.
I think it was ctrl+alt+right, but if that doesn't work, try the other three arrow keys.
However, if that doesn't work (especially if you do not have intel video), then right click on your desktop, go to properties, and go to the advanced tab. There you should find some setting that will allow you to reverse the rotation.
Dec 06, 2007 | Logitech Cordless Desktop EX110
Gateway m305crv laptop
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
May 17, 2006 | Gateway M305CRV Notebook
Gateway 2520915 Keyboard Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
