Question about Dell Inspiron B130 Notebook
USB Port has failed; 4E00:032B
I have 3 ports. One has fail. One works fine.
I ran the disk that comes with the computer-Drivers and Utilities disk-and i get the following error message:
Error Code:4E00:032B, and
Msg: USB Controller 0 Shows an over-current indication on Port A.
I've deleted and re-installed ALL drivers. I've tested certain devices and they all work on one port but not another.
Can someone please guide me as to how to go about fixing these this problem.-->
  • Jay
    Jay Dec 23, 2008
    Ok, you said it might solve this port problem by resetting the port in the dialog box. I am anxious to know where to find the dialog box??? I sure don't won't to have to buy another motherboard.
    Scholar:
  • 130 Answers
Electrical surge on hub port. Either a device attached to the port, or the port itself, has drawn more current than allowed, and the hub turned off the port. The port will not function correctly until you reset it. If the device is the cause, it must be detached before resetting the port. To reset the port, disconnect the device, and then click Reset in the dialog box. If the port is the cause, close the dialog box, and do the following to re-enable the port:
Disconnect the hub.
Re-attach the hub.
If it is the root hub, unplug all attached USB devices from the computer, and (if they have power supplies) unplug them from the electric supply. After a few moments, reconnect the devices. The computer can be restarted at any time.-->
Posted on Dec 22, 2008
One of the usb attached in my computer is not working properly and the window has failled to install its drivers
Everything fails. Try and re seat the card and if it doesn't work try in a different port.
Apr 14, 2013 | Dell Latitude E5420 Laptop Computer
Usb port hub does not recognize external hard drive
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Jul 05, 2012 | Rocketfish 4Port HiSpeed USB Hub
My 8G usb can't be detected by my computer, my flash drive was brought 3 months ago and only half of it was used
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 11, 2011 | Office Equipment & Supplies
Webcam installation
When you installed the camera did you use generic Windows drivers? If so, try going to the logitech website and downloading the latest drivers for the web-cam. Unplug the camera before installing the new drivers, it may prompt you to plug in your camera, if not plug it in once the installation is complete. Restart your computer and make sure your plugged in as well if it is a laptop. Another reason for no response could be no power is coming through the USB port, either because the power connection is burnt out (this doesn't mean that powered USB devices don't work in the port) or it reverted to a 1.1 version of USB. This is a common glitch that can usually be fixed by changing USB ports or restarting the computer. Make sure you don't have too many devices being powered only through the USB port. If any USB product also comes with an adapter always use that adapter if possible instead of using the USB to power it. This will ensure a longer life of your ports. If the latest drivers are installed and you know you have a working USB port that provides power then you more than likely have a bum camera. (Electronics generally fail either very early or very late in their life cycle)
Jul 11, 2010 | Logitech QuickCam Connect Webcam
The computer no longer sees my 320 gb hard drive, do i need to download new drivers? if ao where do i find them.
Possibilities:
1. dead USB port on your computer -- try another port.
2. try a different USB cable.
3. try your external drive on some other computer, to see if it works at all.
4. open the casing, and separate the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive, thus bypassing that adapter, to see if the adapter has failed, or if the disk-drive itself has failed.
5. Google-search for a commercial "data recovery service" -- such companies can disassemble your disk-drive, and fix it, just long-enough to copy all your photos/music onto a brand-new disk-drive.
Jan 25, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
The computer no longer sees my 320 gb hard drive, do i need to download new drivers? if ao where do i find them. i store all my photo's and music on this hard drive
Possibilities:
Jan 25, 2010 | SimpleTech 320GB SimpleDrive External by...
Usb pulled out during use now not working
Sometimes when a flash memory stick or USB hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory or USB external hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 27, 2009 | Western Digital My Book (WDG1U2500)...
My 8gb kingston flashdrive is showing up as usb not recognised on my laptop but my 1gb is fine .What shoukd i do?
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 09, 2009 | Kensington Electronics - Others
When I put my DaneElec 4GB USB Drive into my USB port, nothing happens. We have Vista.
Do other USB devices work when you plug them in the USB port?
If they don't then you have a faulty USB port otherwise the DaneElec is faulty or needs formatting.
Oct 18, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
My westerndigital passport size hard disk of size 320gb when connected to system at starting 2 to 3 beep sounds i am hearing and the hard disk is not detecting what to do? naresh
Either the USB-to-disk-drive adapter inside the casing has failed,
or your USB port has failed,
or the disk-drive inside the casing has failed.
Try a different USB port. Try a different computer.
Disassemble the casing, and remove the disk-drive.
Temporarily attach it as a "slave" drive in a desktop computer,
and see if the drive is detected, and if the files are OK.
If all else fails, and the Passport is still under warranty, exercise the warranty.
Apr 15, 2009 | Western Digital Passport 320GB External...
Dell Inspiron B130 Notebook Logo
1,084 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
