Question about Sony PlayStation Portable (PSP) Console
Problem with umd case
When i insert a umd , when i start the game it starts making a scratching sound as if the umd is hitting something , i am totaly cluless please help
  • 1 more comment
  • rea schulte
    rea schulte Apr 11, 2007
    there are no metals or anything hanging loose in the umd case or bent maetals
  • rea schulte
    rea schulte Apr 28, 2007
    thamks a thousand "guest" it really works
  • Tronan Dec 22, 2007
    i just got my psp, and the first game i got was untold legends: brotherhood of the blade, it was used but seems to be in good condition. whenever a part of the game is loading, the disc makes a very annoying scratching sound which makes me worried something bad is happening. i haven't had any problems playing the game though. the only thing i've done ischek this page for ideas.
Reset your settings and for some reason it will play them again i found!!!
Posted on Apr 24, 2007
  • Sony Expert
  • 311 Answers
Look down the case it there any thing hanging loose and bent metal and are there marks on the umd case or disk
Posted on Apr 09, 2007
SOURCE:
Error 80010087
Check the firmware of your PSP. Some games may not work if the latest firmware is not installed.
You usually get this message if the UMD has errors reading or the UMD is not present or was ejected in the middle of playing a game. You should try testing your PSP with other disks, if it doesn't have the same problem with other disks then your UMD is most likely scratched or damaged.
If you are using a modded PSP then you will get this error if you load a game from the memory stick without having a disk inserted in the drive. Or if the game that you are trying to load requires a higher firmware version. You will need to install a higher modded firmware to fix the error if that is your case.
Hope this helps.
Jun 29, 2011 | Sony PlayStation Portable (PSP) Console
Ds is not reading games
Make sure that no connecting leads are bent or broken in the game or console. If there's some visibly bad scratches on these leads, it can theoretically ruin the connection. Other than that, it may be simply a digital problem, which is not really my realm. I'm more of an analog guy.
Jun 03, 2010 | Nintendo DS Lite Console
PSP trouble reading UMD
its cause the game probably is kind of scratch or the laser lens its damage or its dirty. the noise its normal because its trying to read the disc.
Jun 02, 2010 | Sony PlayStation Portable (PSP) Console
My psp won't load umd's and all i hear is a scrathing sound
The UMD laser might be dirty or broken. Open up the UMD drive and give the laser a clean with a lint-free cloth. Then pop the disk back in and try again. If that doesn't work, you will need to get the PSP repaired or buy a replacement laser and do it yourself.
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
My PSP won't read the UMD's
that's odd, this has happened to me in a similiar way, except for me my PSP would keep saying "Do you want to exit the game?" For you two, i would recommend examining the discs and make sure they're not scratched too much. Also examine the inside of your PSP where you insert the UMD, is there a loose or broken piece. In my opinion, much like my PS2, the games get too scratched (despite being in that case) to function and will stop being real altogether, although i am still trying to figure out why all games stop working...
Hope this helped in any way
Mar 28, 2009 | Sony PlayStation Portable (PSP) Console
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
Psp-lazer ain't reading the games
This link should help.
  • Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
  • Try playing the UMD on a different PSP system. If the UMD plays, the original PSP system may be the problem. If the UMD does not play, the problem may be isolated to the UMD itself.
  • Try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Make sure the exposed UMD surface and plastic casing is not damaged[2]. Do not use if plastic casing is cracked, collapsed, or if foreign materials have entered inside the UMD enclosure.
Nov 10, 2007 | Sony PlayStation Portable (PSP) Console
My psp doesnt read UMDs properly
I started to have this problem with the games that I play all the time. What I noticed is that the game starts to sink into the case. I got mine to play by first, pushing on the reading side of the disk. Later, I had to take the plastic front piece off that has the UMD label. You have to be careful because the actual UMD disk can come out after that. You also have to be careful because you don't want to crack the whit case that holds the UMD. I hope that this helps.
Apr 06, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
80 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
