-   Door plastic post actuator for safety switch is broken off. Caused by plastic liner bags blocking switch opening.-   imokay
Solution #1
posted on Aug 08, 2005
Peter1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
1) Door may be out of adjustment 2) Defective P.C. Board 3) Shredder not sitting properly on cabinet. Try to adjust the shredder on the cabinet or carefully adjust the door. Call for a service call if neither cause the light to go off.
PROBLEM SOLVED for my C-14! The infra-red LED used to detect when the basket is full was weak. This was tripping the door ajar warning indicator. Replaced with a new IR LED from Radio Shack and problem solved!
If this 2nd LED fails, then the problem is too much drive current causing the fail. Will then have to change the LED resistor. Will update here if I ultimately need to change the resistor.
Was this helpful?
Yes
No
Solution #3
posted on Apr 24, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Have the same problem with my C14 too. Door switch replacement didn't fix. Replaced all filter caps on the controller PCB and didn't fix either. So problem is not a bad switch or motor noise.
Now investigating IR LED that detects full bin as the culprit.
On our AMS-500, the Comber spacers are worn out. Should I replace these alone or should replace...
(More)
On our AMS-500, the Comber spacers are worn out. Should I replace these alone or should replace Crosscuters also?
Have "Techsolutions TS4500 Paper Shredder" Power on, Green light On. safety switch...
(More)
Have "Techsolutions TS4500 Paper Shredder" Power on, Green light On. safety switch operating correctly. Removed all 7 screws (7th was under serial # Strip). Everthing appears OK . gearing appear to be very tight, is that to be expected? Should I be able to turn the mechanism bu hand?
I am getting trouble with deep freeze software which restores system whenever i switch off how to...
(More)
I am getting trouble with deep freeze software which restores system whenever i switch off how to fix this?
