Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Canon powershot sd900
I dropped my camera on the ground with its lens still out, now when i turn on the camera it says "lens error,restart camera", i have tried poening it but have troubles getting off the case, i have tried restarting it and pulling out the battery nothing works , please help
  • 5 more comments
  • rea schulte
    rea schulte Aug 25, 2007
    sorry i sold mine, so dont know
  • Anonymous Nov 05, 2007
    Same problem. Did not drop it. I see that many many people have the same problem. Looks like a design flaw.
  • Anonymous Mar 10, 2008
    A mi me pasa lo mismo. En español: error en objetivo. Resetea la cámara.
    ¿Quien me puede ayudar?
    Saludos
  • Anonymous Jun 21, 2008
    THE LENS ON MY CAMERA IS STUCK AND CANT GET IT 2 GO BACK DOWN AND IT SAYS THAT I NEED 2 RESTART THE CAMERA BUT I DONT KNOW HOW
  • Anonymous Aug 14, 2008
    my camera fell an now the lance stuck how can i fix it
  • sjjtssamm Aug 14, 2008
    Canon SD900 - Lens will not retract. The camera has not been dropped nor has it had anything happen to it to cause the lens to get "stuck out". When you try to power on the camera, you get "lens error, restart camera". I've restarted, also tried removing the battery and the lense will not retract.
  • 1bohemian Oct 09, 2008
    Same problen, however, I didn't drop the camera. Just faulty design on canons part and though they are aware of the problem they continue to seel these ^*(^$%^* cameras. Too expensive to fix as the problem will re accur. Bad camera!
I have the same problem, but i didnt drop mind. The lens where out when i put on da pack and now it won't start.
Posted on Apr 04, 2008
Canon Ixus 900 Ti ~ Lens error Restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jun 18, 2010 | Canon Digital SD900 / IXUS 900 Ti Digital...
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 08, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Lens error. Restart camera.
this is very common has the camera been near the ocean??? it does not have to be dropped to give you this error. repair on you lens runs 85.00 for repair. or a new lens for 125.00
Jun 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens wont retrack/ camera wont turn on...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 15, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Lens error restart camera
same thing just happened to me today. the little girl that I babysit dropped it about 1 foot to the rug on the ground, not a hard drop at all. so i tried taking out the batteries and hit it on the table (read on other sites) then i gently turned the end of the lens (my lens was stuck out) counter clock wise and it clicked and then worked.
Apr 20, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error, restart camara issue in SD900
Hey GeorgiaPlum,
What is most likely happening is there is damage to the lens or the lens mechanism and you should have the camera looked at by an authorized service technician. I will say that digital camera repairs often exceed the value of the camera, but it can't hurt to get an estimate done. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 05, 2008 | Kodak EasyShare C613 Digital Camera
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon SD900
First off, see if Canon can help you. If not, the following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2007 | Canon Digital SD900 / IXUS 900 Ti Digital...
Canon PowerShot SD600 Digital Camera
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Nov 03, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
