Question about GE Tritonr XL GSD6260JCC Dishwasher
The lower and upper arm spin, but not the middle one. The O-ring on the tube going into the middle spray was missing so I replaced it but it didn't help
SOURCE: small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Posted on Apr 09, 2007
SOURCE: middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
Posted on Jan 08, 2009
SOURCE: middle wash arm doesn't turn on quiet power 1 ge dishwasher
This arm turns due to water pressure in a small hose attached in the back of the dish chamber. Look inside when the dishwasher is empty and you will most likely see that the hose feeding the center arm is disconnected. Just push it back on and you will be up and running.
Posted on Jul 27, 2009
SOURCE: upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Posted on Sep 22, 2009
Sep 06, 2010 | Dishwashers
Sep 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Jul 27, 2009 | Dishwashers
May 30, 2009 | Dishwashers
Mar 23, 2009 | GE GLD5800L Dishwasher
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Nov 27, 2008 | Dishwashers
Sep 06, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
810 people viewed this question
Try cleaning the jet openings on the underside of the middle arm. They cause the middle spray spar to spin.
