Question about Xerox Phaser 7300DN Laser Printer
My Xerox Phaser 7300DN Laser Printer has lost its IP address. I recently got rid of XP service pack 3, but the day after that my network WAS working well. and I printed quite a volume of stuff. It was only the next day that I couldn't network anything. My printer has 00000000000 for an IP address.
  • 15,935 Answers
Unplug and shut down everything for 5 min...... then plug in/reboot in this order....
PC
Router
Printer
Wait until each has started up fully before going to the next item.
Posted on Dec 22, 2008
I have a desktop which is connect to my router and works perfectly fine. I am running win xp pro. I also have a laptop which i connect wirelessly via the router. The problem is when directly connect to...
The ip address conflict is likely caused by a manual IP address that is entered into the printer that is overlapping with an automatic address that your router is giving out. Either switch your printer to DHCP so it gets an automatic address, or reserve the address in the router's DHCP list or pick a manual address to assign that is outside of the range of the DHCP server. Most router will start at address XXX.XXX.XXX.100 so if you pick an address between 20 and 40 then you should not have any more issues with conflicts.
May 11, 2011 | Xerox Phaser 7750DN Laser Printer
We have Phaser 7300's. Our secuty team tell me that we must remove a SNMP Default Community Name vulnerability ny 1) disable or remove snmp services, 2) disable or remove the detected community name of...
1. Open the web management page in your browser. Just put in "http://xxx.xxx.xxx" where the IP address of the printer replaces the x's. 2. Click on "Properties" 3. In the box on the left side, click to open the "Security" folder 4. Click on "Security Settings" 5. Find the line for "SNMP Read" and uncheck the box under "Any User" 6. Find the line for "SNMP Write" and uncheck the box under "Any User" 7. Click on "Save Changes'
That should cover it. Also posted a video showing the steps on youtube. Should be linked from here.
Feb 02, 2010 | Xerox Phaser 7300DN Laser Printer
How to find the ip address for Xerox phaser 8560?
Is this a network printer?
I would normally expect a network printer IP address to be assigned dynamically assigned every time it comes online.
Dec 16, 2009 | Xerox Phaser 8560MFP Laser Printer
How do I check the history of the number of prints on my Xerox Phaser 8550?
connect to network
type ip address on any machine in the same network
in the webinterface you can see the all details
Oct 27, 2009 | Xerox Phaser 8550DX Laser Printer
Advice phaser 7300dn appear 10: eeprom ,help me please!
The only thing you can do is attempt a reboot and hope for the best, otherwise call out an engineer to repair it! Or you could try and NVRAM reset but I'm not sure if that will work and be careful because you will set the machine to factory settings and may have to do a colour calibration all over again. Let me know how it goes.
Resetting all settings to default (NVRAM)
Resetting the NVRAM will reset all printer values including network, printer setup, job defaults, and color calibrations.
  1. Press the Down arrow key and scroll to Support.
  2. Press the OK key.
  3. Press the Down arrow key and scroll to Service Tools Menu.
  4. Press the OK key.
  5. Reset NVRAM will be displayed.
  6. Press the OK key.
  7. Reset NVRAM and Reset Printer NOW will be displayed.
  8. Press the OK key to reset all the settings to default.
Dec 11, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Sep 27, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Jun 19, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser Networking
Have you tried just reinstalling from original Xerox CD. This worked for us in a similiar situation.
Oct 12, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
