Question about Amana Refrigerators
Amana fridge Ice Maker not working
We own an AMANA refrigerator and the Ice Maker model IC6
is no longer pumping water into the Ice Maker trough.
Do you have any suggestions ?
Could the line be plugged or do you believe it mauy be the Water
Valve.
What do you think I should try ?
THank You
Richard Duy
catriver
  • 878 Answers
SOURCE: NO ICE - IC6
George, the ice maker will cycle about every 2.5 hours. Sometimes it takes a couple cycles to prime the lines. You can remove the white cover of the ice maker. On the module you will see two ports, one marked L and another marked V on the left side. Take a insulated jumper wire and jump these two terminals. You are now sending 120V to the valve. See if the water starts coming in. Also make sure the bailing arm is down. Catriver...post back.
Posted on Nov 05, 2006
Mine was slow-to-none in ice making for a couple of years. One day for the first time I used the built in water dispenser. The long copper line feeding water was full of air gaps. After I bled that out, it has been perfect ever since.
Posted on Sep 09, 2007
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
rickzilla
  • 706 Answers
SOURCE: amana ic6 ice maker
sounds like your ice maker is working properly and that maybe you pinched the water line when you reinstalled it back into the elbow.. is the elbow clear of any ice build up or foreighn matter that would restrict the flow of water into the ice mold tray? If so..that's your problem.. ( thaw it out or melt it and then you should be OK) Hope that helps..
Posted on Aug 19, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Amana drs2663bw ice maker drips water into the back of the ice bin forming an ice build up
Make sure your refrigerator is level. also check that the ice maker inside the refrigerator is level after leveling the fridge.
Jul 20, 2012 | Amana ARS9266BS Side by Side Refrigerator
The ice maker no longer works, plastic line seems
Check the water spout inside the freezer just above the ice tray at the back of the fridge to see if in is blocked with frozen water (ice). If so, you'll have to thaw it and replace it and try again.
Sep 09, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Jun 21, 2009 | Amana Refrigerators
No water comes automatically to the ice maker
What you need is a new ice maker the front gear is not engaging the contacts, you can buy the front module only ( what u put the wire in to on the l & v contact ) but a whole new ice maker assy is the same price.
Jan 10, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ic6 ice maker
Aug 18, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
My amana sise by side fridge wont drop the ice
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Jul 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any...
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Jun 09, 2008 | Amana Refrigerators
Amana SZD26VW about 10 years old - no water or ice
probaly the water inlet pump behind the fridge is defective or the filters are clogged I'd change the filter first if this dosen't help i'd say change the water inlet pump
May 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
NO ICE - IC6
Nov 05, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
267 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
