Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi line cutter - petrol lines all broken
Petrol lines are broken and I need the configuration on how to replace with new lines.
Does anybody know the correct way to install the new lines?
Thanks
  • 50 Answers
Petrol lines disintegrate when fuel is stored in the trimmer for long periods of time. These can be obtained from any small tool repair store. Just remove them and install new ones. They just slip through the holes in the tank, re-attach the fuel filter on the supply line. Make sure that the line is long enough so that the filter rests on the back/bottom corner of the tank. Be sure that the lines are attached to the proper ports on the carb>
Posted on Jan 03, 2009
Why is my petrol tank pressurised in my petrol blower?
There will always be some pressure in the tank, if the fuel in your area is poor quaility i have seen the fuel actually boil in the tank increasing the pressure and causing poor running.
Feb 23, 2013 | Ryobi Garden
Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Oct 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
Hi,My Ryobi 30 Petrol with Brush Cutter attachment has so much vibration I cant use it..
This is likely a mechanical problem caused by either 1. A serious imbalance with the cutter attatched to it 2. The engine is failing and the main crankshaft bearings are worn causing crankshaft "wobble" setting up the heavy vibration you speak of.
Aug 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi petrol weed eater
SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
Dec 08, 2009 | Ryobi Garden
I am looking for Ryobi brush cutter parts
Any local small engine service shop should have these parts in stock. Its called a 'primer bulb'.
Determine if the primer bulb is part of the carb or sperate from the carb with fuel lines connecting them. If seperate remember how the 2 lines get connected when you remove the bulb and replace with a new one. If a part of the carb...
You need to determine if the carb is a Zama or Walbro. It will have the name stamped on the carb. All Zama carbs use the same bulb. Walbro has a small and large bulb.
It would be worth while to install a new carb kit while you have the carb off and apart
Nov 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
RYOBI RBL-30MVA 30cc when pressing the primer bulb to allow petrol thro, nothing happens? and as its not letting the petrol thro, the leaf blower will not start....any suggestions? thanks ben.
The diaphragm in the carb may need to be replaced. Make sure all your fuel lines are fine. On these inexpensive blowers the fuel lines tend to get brittle and crack and fall apart.
Oct 08, 2009 | Ryobi Garden
Manual for Ryobi Grass Scorpion Line Trimmer
my ryobi scorpion only has twofuel lines but two on primer can you help
Mar 13, 2009 | Ryobi Garden
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
205 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
