Question about Gateway 504GR PC Desktop
Noisy My computer has started making noises. It has been suggested to me that it is the fan and that maybe I need to clean it with compressed air. i do not know how to open the tower. Please advise Thanks
  • lauralsander Dec 22, 2008
    ok---I feel like a complete spaz/ there are 2 big screws that unscrew by hand---which I did, but cannot remove either side.---and I'm not sure which side will open. I don't know what the motherboard looks like......
  • 2,794 Answers
I believe that tower has a plastic clip on the back of it to open the tower. Just pinch the ends and the door will pop open. This looks like a similiar Gateway tower I'm working on for a client right now.
Posted on Dec 28, 2008
    Problem Solver:
  • 3 Answers
One side off the tower should come off. There should be two screws holding it on, located on the back. If it's like most towers, the left side comes off.
Posted on Dec 22, 2008
  • uberphokis
    uberphokis Dec 23, 2008
    Try sliding the panel to the back of the unit. You might have to be a little rough with it, sometimes they get stuck.
  • 100 Answers
There are two screws on the back of ur tower for each side supporting plate .remove the side plate which is on the other side of ur motherboard.then just blow out all the dust with a air blower.
Dell Studio fan unbearable noise
It might be cloged and unballanced with dust Try using a compressed air cleaning bottled . to remove the dust, if it is still making noise I would suggest that you have it repaires because if it stop completely it could overheat your motherbord and cause dammage
Nov 26, 2012 | Dell Studio 15 Laptop
Noisy computer after cleaning fan
If you used compressed air, the fan maybe was rotating too much when you blowed it. If you damaged it, replace it.
Feb 01, 2012 | Acer Computers & Internet
CF-Y7 After you start using the notebook for a while the fan starts making noise (sounds like the fan increases in speed and is noisy). There doesn't seem to be much heat coming out of the vent, just...
There are intake vents on the bottom of the notebook. Make sure these vents are not obstructed by putting the notebook on a flat hard surface when in use. You may also want to get a can of compressed air and clean out the notebook. Just spray the compressed air in the intake vents on the bottom and spray in the exhaust vents on the sides.
Also, make sure there is no CD/DVD in the optical drive. Sometimes these will spin and the sound can resemble a fan.
Mar 14, 2011 | Panasonic CFY7 C2D/1.8 14.1SXGA 1GB-80GB...
HP dv6810us laptop fan too noisy? Any solutions?
Here is a simple guide to cleaning your laptop fan if your are comfortable opening the computer.
http://www.rightinfonow.com/laptop-noise
If not it is most likely that the fan is clogged with dirt and dust and just needs cleaning. If blasting it externally with compressed air does not work you or a local tech will need to open the computer and clean it.
Thanks
Dustin
Jan 12, 2011 | HP Pavilion dv6810us Turion Notebook
Fan motor is noisy and loud. Also, the laptop freezes often and must be reboot or restored
I believe your fan is not doing its job. You need to clean the case out (compressed air) and try it. Actually, since you are having that problem, I'd go for a new fan. What you seem to have is a heat problem.
Oct 19, 2010 | Compaq Presario 700 470024-192 Notebook
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
Dell dimension 4700 power supply fan has gotten very loud
i'm not sure whats wrong with it put it maybe that the bearings in the fan are bad i suggest that you get a new fan:)
Jan 04, 2009 | Dell Dimension 4700 PC Desktop
Sony 46'' WEGA TV
The mirror assembly has no moving parts, this unit has a minimum of 3 fans! if the fan blades get too dusty the fan will get noisy. Try cleaning the fans with compressed air.
Jan 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Noisy fans laptop overheating?
Try using Compressed Air in a can by the vents. I would not recommend taking apart the laptop.
Dec 22, 2008 | Computers & Internet
Loud Dell desktop
Any fan that is making noise you would need to replace. There is also never a need to use alcohol to clean a fan. Some computer air or a light wipe down will do just fine.
If you have any other questions let me know.
Thanks,
Lee
Jun 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Gateway 504GR PC Desktop Logo
181 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
