Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5, STKs changed, getting blue screen but not pict
First was having problem with the power, not turning on going from green to red light. changed the stk as advise in site, now turns on but getting a blue screen overlaping on green and red, getting sound but not picture, any help will be appreciated.
  • Ed Taveras Dec 22, 2008
    thanks for reply, the first ICs were stk392-110 change for 180s, but picture was ok before changing ICs
  • ladywinn
    ladywinn May 11, 2010
    Was the old STKs were they STK392-110s and did you replace both of them? I always upgrade with STK392-180s they are King of ics when it comes to the 110s. Also if they are 110s chances are they are no good. You can order STKs at Electronix Parts 1-800-223-3205. Another thing go bad and recheck where you have solder make sure everything is ok there .
    Problem Solver:
  • 13 Answers
Did you have double image before changing the stk's ? If not then there was no need to change them.. Pioneers are known for bad solder connections especially in the power supply section.. suggest checking that when you changed the stk's that there are no solder bridges between the pins of either stk ICs
Posted on Dec 22, 2008
How do i switch my sd-533hd5 to hdtv
the only way to do this is u most upgrade ur cable box to hd box then connected to a component with the color green blue and red on the back of ur tv
Nov 03, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 53in.the colors will divide into the blue green and red. then blow a fuse ?
from what i have had in the past was with this problem was convergence problems but it seems to be something originating from your main board.
Nov 06, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD 533HD5 has pink screen
Sounds like the gun is trying to fire up but has internal problems. You may want to see if you want to tackle the job of changing it out. Check with MCM Electronics to see cost of a new gun. 1-800-543-4330 or www.mcmelectronics.com
Jan 17, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My pioneer model sd-533hd5 shuts off after 5 mins and goes to stand buy
Replace Both of your STKs ,if it has the STK392-110s do not go back with these they do not hold up use STK392-180s for parts call Electronix Parts 1-800-223-3205.
Dec 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 - Red bowing at the bottom of the screen
Convergence amp. IC's on power supply PCB need replacement.
Part # STK392-110 sub to upgrade STK394-160E. I use Hitachi ,
no re-calls! Not advisable to use generics......
Worth repairing unless you are ready for a change......T.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Flashing Green
I would guess that your problem is similiar to mine but mine is with the color red. The CRT went out which is a 400 dollar part and who knows how hard to fix.
Nov 21, 2006 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
165 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
