Debris filter hi ive got a samsung p1453 and i can't seem to get the debris filter out ive removed the cap but how do you get the filter out or do you have to remove the pump
Did you ever find an answer? I am experiencing the same problem :(
Posted on Feb 08, 2010
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
What is the meaning of D02 in Samsung watching machine
D02 Error may have following Causes:
1-drain hose kinked or plugged
2- drain pump failure
3- accumulation of debris in filters and causing the floater positioner got stuck
if there is the flow of water through the drain hose it may that the floater inside the bath got stuck, if this is the case, remove the filters, unfasten the bolts and remove the inside cap until you can see the floater.
clean debris from inside surface of the washing machine and also clean the floater.
Posted on Aug 21, 2015
Dec 19, 2015 | Samsung Washing Machines
DOOR IS NOT LOCKED
This video will show you how to open your samsung washing machine P1453 door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2013 | Washing Machines
Error code d02 on samsung dishwasher dmb28afw
d02 Error may have following Causes:
Dec 21, 2012 | Samsung DMB28AFW Dishwasher
Samsung p1453 will not drain or spin
5E (or SE error) is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle.
The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | Washing Machines
(Samsung WF330ANW) The front-mounted debris filter seems unclogged but I get a small gush of clear water, about 1/2 to 3/4 cup, whenever I remove the filter cap to check after a wash. I check frequently...
If I understand you correctly that the filter cap does not come off easily try pouring anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 14, 2011 | Samsung Washing Machines
I wonder why there is still water left inside my front load after draining. It used to be totally drained. But now as you turn the drum by hand you can hear water inside of it. My samsung is Wd 6102
Hi the likely problem is a blocked drain filter or a bad pump. Their will either be a small door at the front right or a removable panel under the door. gain access to the pump and beside the pump there will be what looks like a gas cap on a car. unscrew it and clean the filter. If you don't see too much that would block the filter then your problem is the pump replace it. If you have any other questions please feel free to comment. Mike
Dec 06, 2009 | Samsung Washing Machines
MY SAMSUNG P1453 WASHING MACHINE WON'T SPIN
Empty the debris filter at the bottom (take the bottom bit off and turn the dial thingy) There will be water coming out so put towels down.
Aug 25, 2008 | Washing Machines
I have a samsung P1453 washing machine and it refuses to spin, I have checked the obvious like filter and discharge hose,. Is there some sort of sensor to check for load in-balance
hi i also have a samsung p1453 that will not spin when the digital counter gets to 9 mins remaining it jumps back to 10 mins and wont go through the spin cycle the pump is working fine and emptying as it should cann ot see anything blown on the pcb
any advise woulkd be appreciated
May 14, 2008 | Washing Machines
Washing Machines Logo
411 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
