Question about Stoves Kitchen Ranges
Can't turn oven on
Kenmore C970 625431
gave the touch pad buttons a good cleaning and now whatever touch pad i touch..oven says OFF. stove top works fine
I guess needs resetting but can't find my manual for troubleshooting, etc
Unplugged stove for several minutes and it set it...
Posted on Dec 24, 2008
My Ge Stove Xl44 model JGBP79 the oven will not turn off, all other button seem to work but this one
It is possible the touch pad is not working. If you unplug the stove and the oven shuts off then it is more that likely the touch pad.
Sep 25, 2014 | Kitchen Ranges
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2010 | Magic Chef Kitchen Ranges
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
Kenmore elite double oven control panel
I just purchased the kenmore elite double oven with the touch pad control centre. Has anyone had any problems with the control panel on these ovens?
Dec 13, 2008 | Kitchen Ranges
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven
Is this an electronic control oven...touch pads to set temp? May have a bad ERC. Electronic Range Control. Also check oven sensor. This is steel rod in oven in back wall near top on left or right. Check ohms from the rear where it connects to harness. Disconnect at harness and measure resistance of sensor. Most are around 1.1k.
Oct 07, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
624 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Carmen Mikulic
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
