Question about Whirlpool AWM5125/1 Front Load Washer
Amana washer won't fill with water
Amana distinction cloths washer will not start the new wash cycle. Water gets to the machine but won't fill the tub. When knob is set, machine sounds and fills like it will start but no water and the machine shuts down. When the empty tub is manually turned there sounds like water is still in the machine below the tub.
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Posted on Dec 24, 2008
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
Hello. I have a Amana top laod washer. My washer will spin(i can hear it spin and see it shakes as it spin). My washer will not fill with water when I turn it to a washer cycle. No water will fill in this...
If you're not getting any water (hot or cold), you'll need to check voltage coming to the solenoid valve. This is the valve the hoses connect to on the back of the washer. If you're not getting voltage during the fill cycle, your timer is the most likely culprit.
Jan 01, 2018 | Amana Washing Machines
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Amana lw8303 clothes washer will not run or drain
I had similar situation. and changed out the water pump on my washing machine. it works great now.
Aug 29, 2012 | Amana Washing Machines
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Whirlpool AWM5125/1 Front Load Washer Logo
1,396 people viewed this question
Dan Webster
Dan Webster
Sal De
