Question about HP PSC 2510 All-In-One InkJet Printer
HP PCS 2510 Scanner module keeps running
The scanner on my all in one seems to have malfunctioned. After I had attempted to scan, it just got stuck scanning in one spot towards the end near the keypad. Even though I have unpluged the power and plugged it back to try to ''reset'' the darn thing contiues to do the same. The buttons do not respond or they are delayed for a prolonged period of time. If I hit the power button while it is stuck scanning, power down will take more than a min or two. HELP!
  • starfirezhu Feb 01, 2009
    well, I got just the very same problem! Hope there will be someone able to help us out. Praying...
Step 1: Unplug all in one printer scanner power plug and USB plug. unplug power adapter from wall wait 30 seconds
step 2: plug power adapter in to wall leave usb unplugged.
step 3: Press and hold # + 3 for partial reset then plug power plug in to Printer till the words Partial Reset appear.
this should get you out of the trapped scanner bar. that 5mm high ring fix is just pure nonsense its been tried and debunked as a fake fix. if steps one through three do not work. try leaving it unplugged a few days. if that don't work seek professional help.. or buy a new printer scanner
Posted on Sep 13, 2011
Do not understand this proposed solution but wish I did since I have this same problem.
Posted on Jul 28, 2010
Please follow my steps:
1. Make a ring, which is 5mm high and 1/3 cut so that it can be mounted at the far right end of the rail bar where the scanner module sliding back and forth. This can help get the none-stopping scanner out of the trap!
2. Do the Semi-Reset opreation. Then you can see the healing result!
Posted on Feb 18, 2009
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
My scanner is not returning it seems to be stuck
I have had good luck fixing that problem by opening up the scanner and cleaning the rails with alcohol then very lightly lubricating them.
Feb 28, 2015 | HP Scanjet G2410 Flatbed Scanner
Hp 2515 scanner - creating a multi-page scanned pdf document
How about building a PDF scanner using some manual tools to help with the PDF scanning project? I am testing about the related programmes these days. You can also google it and have a try. Good luck.
Best regrads,
Arron
Tutorial PDF Document in VB NET Overview
Feb 13, 2013 | HP PSC 2510 All-In-One InkJet Printer
Hp officejet 6500 all in one, scanner suddenly quit working, small office network only two pcs, printer function works, but scanner says no connection? Removed HP driver, Reinstalled whole thing from Hp...
The scanner has a separate driver. Go to Device Manager and click "Imaging Devices." Is the scanner there? If yes, try to update driver. If it's not there, right click and select "scan for hardware changes." Plug and play should see the scanner and install it. If not, go to control panel, hardware, add device. Keep the disk in the machine, as you know it has the drivers on it. If there is a newer driver online, you can update later.
Aug 13, 2017 | HP Officejet 4315v All-In-One InkJet...
Scanner on my hp 2510 photosmart all-in-one is not working when i start go up to the end right of the prenter and and make a nize then nothing work
This is a problem in scanner section on your printer.You need to disassembly the printer and pull out the scanner section.Open the cover of scanner section and you'll see the mirrors inside.You need to clean the ash from these mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Nov 13, 2009 | HP PSC 2510 All-In-One InkJet Printer
HP scanjet 3970will not operated with vista o/s,
Decided I would be spending more time and effort than this scanner was worth. I went and purchased an Epsom. My plan is to rid my house of everything HP. They are not the company they were for so many years, must be the cost accountants are running the show.
Oct 31, 2009 | HP ScanJet 3970 Flatbed Scanner
HP Scanjet 3970
This might probably help, see the Diagnostic description, Patch etc... to download, havn't tried it yet but maybe its the solution for errors.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=298549&prodTypeId=15179&prodSeriesId=298547&swLang=8&taskId=135&swEnvOID=228
Jul 26, 2008 | HP scanjet 3970 digital flatbed scanner
Scanner doesn't work
If you've tried the printer on different PCs and still didn't work looks like there is something wrong with the scanner internally. When you start the scanner fresh, the scanning light has to move up and down the glass if it doesn't may be something is stuck on the mechanism open it and check for lose cables or dirt. Other option will be that If you bought it on the last 11 months try send it for "Manufacturer's Warranty Repair" you can call HP costumer service and ask them where you can send your unit for service, make sure you use a traceable method and keep records. Or take it to the nearest dealer and have them look at it.
Aug 26, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2510 All-In-One InkJet Printer Logo
368 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
