Question about Philips 26PF5320 26 in. LCD Television
Philips 26pf5320 i have a 26 inch philips lcd. on day it was working fine( i was watching tv on cable) then i decided to plug in my laptop to watch a movie. after the movie i switched back to tv and then i couldnt get back all my channels. i examined all connections etc.....nohing. the other 4 tvs in the house were working fine. i tried channel scanning and got channels 2 to 12 and 66 to 74. i dunno whats up. any suggestions before i pay to have it repaired will be greatly appreciated. thank you guys.
  • Anonymous Mar 30, 2014
    I'm watching a movie on TV and there is audio description of what's happening. How do I turn it off? It's only on one TV, none of the other TVs in the house are doing this.
    Sergeant:
    Champion:
  • 326 Answers
Hello, one of possible solutions is to replace T7735 by the same type of transistor and L5753 (220uH use 470uH). This is a job for a technician. Best regards, Arpi
Posted on Apr 26, 2007
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
I have a Panasoniv 32 inch vivera lcd tv. When I watch a movie the picture looks grainy. Kind of like the pixels are not forming to complete the picture. Am I missing a cable or some kind of compnent for...
If you're watching the movie from a DVD player, make sure all of the cables are fully plugged in and connected. If you're watching the movie from a VHS, it will probably continue to look like that.
Feb 28, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
My Philips 42PFL5332D has quit playing my Sony Blu Ray player (model BDV-T10) it was working fine, I finished watching one movie went to put in another and it wouldn't work. Thought it was the Sony,...
Tv still working,with the incomming broadcating tv signal cable plug in,working is fine wright?Tries tv unplug,replug the tv back like an hour later.Let the tv resetting itself back to the factory setting.Go into the tv Menu goto PICTURE,go down to reset the tv Tuner signal board,that to reset the whole entire Tuner signal board back to factory setting,now all the incomming plug&play like the HDMI ports on tv,should work now.Not,than i can't tell what happen to the tv exept the tv Tuner signal board have problems,that it.
Oct 26, 2010 | Philips 42PFL5332D 42 in. LCD Television
Unable 2 watch dishtv in Benq LCD SD3731 with DVD cbl plugged in
The S_Video connection has precedence (most likely named AV1) over the RCA/composite one (better image quality - usually named AV2) so it will be automatically selected. If you want to view thru AV2 input you will have to select it manually every time you want it.
Jan 07, 2010 | Televison & Video
Cant play my xbox 360 on my 22 inch Insignia tv
Is the TV an High Definition TV?
If it's not an HDMI compatible tv them you will need a regular audio video cable for your XBOX 360
you cn get them all day on ebay or at any store.
May 25, 2009 | Insignia 22 in. Widescreen Flat-Panel LCD...
Philips LCD 17PF8946/37 TV not working
The good news is that the "No Input Signal" message means that your TV is not broken. If you are trying to watch cable, then you have simply turned the TV to the wrong input channel. If your cable comes into the Philips using a coaxial cable wire, use the Philips remote to change the channel to Ch.3 or 4 - whichever channel you normally watch cable on. Make sure the cable box is turned on if you have a cable box. If the cable box connects to the TV using another type of wire, use the Ch+/- on the Philips remote and go through all the AV channels until you find the right one. Good luck! Let me know if you need additional help.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips 17PF8946 17 in. HDTV-Ready LCD...
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
MAGNAVOX MWC24T5
Do you have a cable box? if so unplug and plug back in the box. I do have issues with boxes doing that, try unplugging the tv also. what have you done to try to fix it?
Jul 08, 2007 | Philips Magnavox 20MS233S 20" TV
Westinghouse LTV-27w6 27 in. HDTV LCD
Have you unplugged the set from AC power? Not just 'turn it off' but physically remove the power cord for 1 minute. Often this 'resets' internal circuitry when a 'power off' will not.
May 14, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Philips 26PF5320 26 in. LCD Television Logo
233 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
