Question about GE JRS04 Electric Single Oven
My GE electric burner is not working.
I replaced the electric burner element only to find out that the element is OK. So I checked teh voltage with a digital multimeter and I'm only getting about 1 volts AC to the element. Whereas I'm getting 230+ VAC to the other three heating elements.
  • cchow Dec 22, 2008
    Oh btw ... the model is NOT a JRS04 electric oven. It's a different GE electric model with a stainless steel top, 4 electric burners and controls directly over the oven door.
  • cchow Dec 23, 2008
    Thank you. Now I need to figure out how to dismantle the oven (remove the front cover) and also find a place that sells the knob control. I will unplug the oven first, then attempt to disassemble the oven.
  • 306 Answers
The know that controls the burner is bad. Take off the front cover and replace the control knob. Be sure you unplug the stove. Let me know how it goes. ken
ps write down the wiring of the control there are 5 wires going to switch there will be little letters on the switch like l1 l2 P com on writing like that.
Posted on Dec 23, 2008
Electric heating not working
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Mar 31, 2015 | Ovens
Kenmore c970
Surface burners
The infinite switch
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Sep 07, 2014 | Kenmore Stove / Oven / Range Bake Element...
Fan and grill working, no heat
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Surface burners
The infinite switch
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Dec 05, 2013 | Belling XOU252 Electric Single Oven
I have a belling Kensington gas oven, the main oven is not working because there is not electrical power to it, the rest of the appliance and ovens are ok
5.
THINGS TO CHECK:
the broil element
The bake element
Surface burners
The infinite switch
Aug 27, 2013 | Belling Ovens
Whirlpool akg668/wh oven not working
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/ http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
5.
THINGS TO CHECK:
the broil element
The bake element
Surface burners
The infinite switch
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
May 18, 2012 | Whirlpool Ovens
When trying to turn on the front right burner it doesn't heat at all what do I need to replace?
Check the wiring to the element, be careful shock hazard. On my electric range the wires were broken where the element plugs in socket. Socket kits are about $9.00 us If you have a volt meter unplug the element and turn the control on if you have voltage then replace the element. Thanks Tom
Nov 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a ge profile that is 13 years old. the burners work but the oven will not heat, I checked the breaker and turned it off and back on to reset oven but it still does nothing. any thing i might try,...
Greetings,
If you look carefully at the bake element..There may be a burnt spot or not smooth to the touch..If it has any bumps or blemishes...Its bad. If you have an ohm meter you can check the bake element for continuity...if none, its defective......in most cases its the element that goes bad...
If you do have a volt/ohm meter you can check for voltage and I've even seen the wire burn off where it connects to the burner itself...The thing to really be sure of is power going to bake..if not power, its either the board relay keeping it off or a wiring problem...ie burnt wires
Bruce Denton
Dec 12, 2010 | GE Profile JTP18 Electric Single Oven
Need to replace burner on ge profile jsp47
Hi pauli1598, if you are thinking of doing it yourself, let me suggest a quick look at the following link www.ehow.com/how_2262532_diagnose-repair-electric-burner-problem you'll find a complete procedure there and if you don't have a meter you can always exchange the defective element(burner) with one that is working just make sure it is defective. You can always find replacement electric elements in your local appliance parts srore or sears or if you prefer on line ordering www.repairclinic.com you will need the complete brand name and model number.
Jan 08, 2010 | GE Profile JSP47 Electric Single Oven
Top oven will not heat all the controls are active, bottom oven works fine.
check voltage to element. should be 240v. if voltage is good then replace element.
Jun 21, 2009 | GE JKP27 Electric Double Oven
GE JRS04 Electric Single Oven Logo
165 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
