Question about Sony Walkman D-EJ250S Personal CD Player
Doesn't play CDs except via the remote control earphones
I've had this discman for 4 years more or less. It reads CDs but only plays them when I press the play button on the remote control. I can no longer use any buttons on the discman unit itself.
When the CD plays, the skip forward button changes the bass levels, the skip back button can change the play modes (Repeat Once, Shuffle, Repeat All etc), the Stop button actually stops the CD and the Play button gives you different play modes as well
SOURCE: Camera control buttons do not work, stop, play etc
your flexible control panel cable may have torn ( from loading and unloading ) - if there are leds ? in yours , the replacement part often does not have them ( many users miss them ) ; get an estimate , before committing to repairs on a 7 year old camera ( starts at $ 50 plus parts and shipping , here in puerto rico ) ;
Posted on Aug 16, 2007
SOURCE: 2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Posted on Dec 02, 2008
  • 3 Answers
SOURCE: dont know how to change dvd with out useing skip botton
Press the Display button located in the middle right of the remote. This brings up a menu on the tv that shows the dvd number. Press the right arrow button to get to the number. You can then enter the number of the dvd you want. After you have entered the number press the enter button. This will cause the desired dvd to load. You press the Display button again to tun off the menu.
Posted on Dec 26, 2008
SOURCE: Sony Mini Hi-Fi MHC-MG110 no longer chooses CDs at random
Unplug the power for a while and load all CDs. It could solve the playing old paylist.
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Posted on Mar 13, 2009
I've got VW Passat b6 2006. Rosen-VW0710-H11 is installed in it. When I try to play DVD (no matter audio or video) system displays message: "Password Fail". What can be the reason of this...
I would recommend resetting the Rosen unit. This is done by entering the "Menu" and pressing "Settings". From this screen, you select "Keypad" in the top right corner of the screen and then enter "7-5-2-3" and press "Enter". This should erase any code for Parental Control (levels 0 - 8). Also, the Rosen product states to only use "Store bought media" for CD's and DVD's meaning that it won't play all 'burned' discs. Hope this helps.- Elliot
Sep 29, 2011 | Car Audio & Video
My unit is a DVP3140, purchased 2006 or 2007. As soon as I got it, I changed the code to region 0 so that I could play the DVDs I bought when I lived in Italy. It worked great for about 3.5 years of...
By changing to Region 0 you've changed the Laser control and subsequently the Laser is failing earlier than it would have done under normal operation.
The only solution would be to replace the Laser which is not normally cost effective and often unavailable anyway.
CDs may still play for a period of time as these require less power as there isn't as much information to read as a DVD.
May 29, 2011 | Philips DVP3140
I am using this to play my newborns nursery CDs and was wondering if there is a repeat function. I don't want his cd to stop after the last song, and can't seem to find that function. I do not know if I am...
Repeat play (Remote control only)
Press [FM MODE/REPEAT] on the remote
control before or during play.
The player will play all the tracks or all the
programmed tracks repeatedly. " " appears
on the display.
To cancel repeat play, press [FM MODE/
REPEAT] again. " " disappears.
Hope this helps you!
Mar 14, 2011 | Sanyo AWM-660 CD Shelf System
I can not get my Crosley CR248 Songwriter to Finalize when I try to transfer from cassette to cd. It keeps showing me FAIL....
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it. Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible. Once you have tried finalising a disk and it has failed you cannot use the same disk again.
Jan 29, 2011 | Crosley CR248 Turntable
How do put a video on the philips mp3
You can't put video on it. It's a discman with mp3 capabilities. Meaning you can play shop purchased cds or play cdr discs with mp3 audio data files on. It sounds as though you are confusing mp3 with mp4. Mp4 is a video codec/file format.
Jan 16, 2011 | Philips Sport Personal CD/MP3 Player
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Mar 13, 2010 | Philips Televison & Video
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or...
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Dec 10, 2009 | Audio Players & Recorders
Playstation 3 wont read some cds or play downloaded demos.
I'm also having this problem as well, it has to do with the OS and it is corrupted. It seems like the "Game mode" has been corrupted preventing us from playing games on the hard drive or reading games.
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Prblem with samsung dvd hr-737
Hi, I have the same problem. Have called Samsung, those **** don't know ****. The player also doesn't recognize DIVX. This is what you get when you buy Korean cheap ****. I've sent mine in the garbage. I was smiling as the garbage collectors came and took it to hell.
Mar 16, 2008 | Televison & Video
Remote Control Earphones
When using either Windows Media Player or Windows Media Player 8 on your Pocket PC e570 you will need to program Media Player to recognise the button functionality of the Remote Control Earphones by following these steps: Select Tools, Buttons. Select each individual function and press the relating button on the remote control. After all buttons have been programmed, press OK which should take you back into Media Player. N.B. The remote control buttons will not function when playing back voice recordings as the earphones can only be used for listening in this mode.
Sep 08, 2005 | Toshiba e570
Sony Walkman D-EJ250S Personal CD Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
