Question about EliteGroup P4VMM2 Motherboard
P4VMM2 - ???
After i switch on the computer, my monitor dosent show anything, but drive A is always running....and after that my monitor automitacally disconneted from cpu....any body can answer this
  • I try to disconnect drive........but nothing happen....basically after switch on comp the monitor show the detecting drive first...how i want make this back to normal.....now show nothing......??? Please help
  • 883 Answers
Try this: find the BIOS reset jumper on motherboard and switch it to on, then after 10 seconds switch it back. then disconnect floppy cables then boot system then enter BIOS setup [F2 or DELETE keys], then "enter the BIOS and look for detect floppy disc and dis-able and ensure that the HDD0 is set as first boot device in standard cmos settings...per sandrew" if success, then problem with floppy drive or cable setup.
Posted on Jun 05, 2007
  • 3 Answers
HI if your floppy light stays on all the time your floppy cable must be installed wrong, be sure that the red line is line up on the pin one side of both the floppy ide on the motherboard and also on the floppy itself. also make sure you don't have a floppy disk inserted in the drive.
Posted on Jun 04, 2007
    President:
  • 2,961 Answers
Disconnect drive 'A' floppy drive and see if it will boot up without it connected. It may be that the floppy is faulty if you know the ide cable is on the correct way round, as your pc may be set to halt on all errors
Posted on Apr 09, 2007
  • andrew pester
    andrew pester Apr 09, 2007
    assuming you have no floppy disc in drive.
    On boot up press F2 Del and enter the bios and look for detect floppy disc and dissable and ensure that the HDD0 is set as first boot device in standard cmos settings.
    press F10 to save and exit and allow a re boot of the pc.
Manual http
Is it plugged in? Is there power to it? Is the computer switched on? Is the computer connected to the monitor? If you give details of the problem, you will get a helpful answer.
May 06, 2013 | EliteGroup P4VMM2 Motherboard
My pc is always freezing.. i did all i can but nothing good happens
>> Do a Power draqin on the computer.
>> Do a Msconfig, disable all startups
>> Do restart the computer with all the peripheral devices disconnected and should not have any disk in the disk drive.
>> Delete the temp and prefetch.
If Still the same issue found ...
>> Do a backup of all the data and run a recovery on the computer.
May 25, 2010 | EliteGroup P4VMM2 Motherboard
WD Notebook Essential 80G just quit working
if you are not getting any broken noise from the hard disk its not ded so ushut down the computer first then connect the hard disk to the power and then connect the hard disk to your system in the usb 2 port then connect the start the system if still dosent detect go to manage by right clicking on the my computer icon the go to disk management check your hard disk shows ther if shows forign just right click on the forigen and say import forigen hard disk if shows the drive helthy and dosent show up on my computer then just right click on the helthy place and say change drive letters and choose one of the letters and should show up on the my computer if still dosent see at all then change the usb cable....
if still dosent work remove hard drive from the external case and put it directly to your computer for this u need a sata cable and a sata power if it detects and work this way your data is safe but you casing of the external hard drive has probs ...
thanks
Nov 12, 2008 | Western Digital 320GB MyBook External USB...
VIDeo CARD not working
You will need drivers for the FX5000 first, disable the driver for the one your using, shut down and then install the new FX5000, boot up and wait until the VGA comes on, it can take several mins sometimes.
Sep 26, 2008 | EliteGroup P4VMM2 Motherboard
Cmos
Hi stan_z4, do you have the manual for you're board?
I'm showing the P4VMM2 is made by ESC = EliteGroup.
Which is not listed above (Intel D845EPI).
If you do have the board EliteGroup P4VMM2 than turn to page 11 in the user manual. The jumper for the cmos/bios JBAT1, Pins must be set to 1 & 2. If JBAT1 is set to pins 2 & 3 you will reset you're bios every time you boot up.
Don't have you're manual? Click on the link.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Mike
Apr 28, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
My pc still won't boot up
The beeps are beep codes. Were they short or long? Also do you know who makes your BIOS?
Jul 26, 2007 | EliteGroup P4VMM2 Motherboard
My pc doesn't boot up
Did you have onboard video before? What is the video card? AGP8x, AGP4x, PCIe? If you had onboard video, you'll need to change the settings in the BIOS and disable the onboard video. You'll have to plug in at the onboard to access the BIOS.
Jul 23, 2007 | EliteGroup P4VMM2 Motherboard
P4vmm2 doesnt boot,Y?
Hi yansky, When you turn the computer on do you see or hear any of the following: -Does the power LED turn on and if so for how long? -When you turn you power on listen closely for any sounds like hard drives or fans starting up. -Does anything show on your monitor, if yes what exactly? -When turned on do you hear any beeping sounds from the computer? If you do listen for the pattern of long and short beeps and let us know what they are. If you see absolutely nothing you should try testing the socket the computer is plugged into. Fuses blow, power strips die cords develop shorts so unplug the computer and plug in a lamp to verify you?re getting power. If that doesn?t turn up anything let us know the answers to the questions above plus any other observations and we?ll try to help.
Jan 13, 2007 | EliteGroup P4VMM2 Motherboard
Suddenly quit and won't start.
Could be a processor failure, but try changing the cmos battery first on the mobo and locate 'JBAT1' terminal on mobo and put jumper across pins 2-3 then back to pins 1-2 and try starting up again.
Jan 09, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
191 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Computer Links
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
