Question about Panasonic NI-R73NR Iron
My iron leaves white residue on clothes when I iron.
I use regular tap water in the iron.
Supposedly vinegar helps. Follow the following link:
http://www.learnhowtoclean.com/clean-an-iron.html
I'd like to use this teachable moment to give a shot out to all the Ray Luv fans out there, the Giant fans out there, and people who flush the urinals after using them.
Posted on Feb 16, 2009
2 Suggested Answers
rtpflh
  • 546 Answers
SOURCE: How can I prevent my iron from leaving white residue on clothes?
white residue is caused by lime in your tap water.perfectly safe to drink,but when boiled [as in making steam] the lime is left behind. over timeit builds up in the 'tank' buy a gallon of distilled water from the grocerery-about $1 mix water with white vinegar,50/50 and 'steam it out' once or twice to remove deposits in the resevior.steam it out again w/pure distilled water.try it out on your husbands clothes before you iron your delicates again!!
Posted on Sep 24, 2009
When I have finished ironing am I supposed to empty the residue water out of the water tank
You may if you wish.
If you do not, and you have no need to use the iron for a long time, the water can evaporate while it is sitting still, and leave a residue of minerals inside the iron, which will, over time, plug up the iron so the steam does no longer work.
That can take many months or a few years.
Using the iron regularly will negate the need to empty it.
God bless your efforts.
May 16, 2016 | Irons
Do I need to use distilled water in my iron?
For best performance and life of the appliance, yes! You can use tap water though if the mineral content is low. However it may build up scale and leave white streaks on dark clothes.
Mar 05, 2016 | Irons
Our iron keeps shutting off and on. It then spurts out brown liquid from the iron. It is on my wall and it stains our clothes
the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
Aug 11, 2010 | Euro-Pro Shark GI490 Iron
While steaming clothing, a white flaky residue is being left on the clothing. Sole plate is clean. Residue seems to be coming from steam vents. What do I do to continue using this great iron? Evelyn Roll
Are you in a hard water or soft water area, maybe you could try using filtered water in your iron. To clear out the scale from the jets try adding a little white vinegar to the water and steaming it through, or a little "Calgon" diluted in water. Then perform a test iron on some dark fabric untill the scale has been removed.
Aug 02, 2010 | Rowenta DX6700 Iron
My iron smells bad and transfers the smell to clothing. I have had my iron for 10 years and love it, but my housekeeper left water in it.
Hey, You have a "Mildew" issue. Just like leaving clothes in the washer too long before putting them into the dryer. If you read your iron's manual, it is recommended to use "Distilled" water...not tap water. Tap water has impurities...Distilled water does not. Here's the fix...MAKE SURE YOU ARE HOME WHEN YOU DO THIS! Get distilled water (From Grocery Store) Mix 1/2 cup distilled water with 1/2 cup vinegar. Put this into your iron and leave it on. To help it along, push the "Steam" button frequently. You can do this several times...the acid in the vinegar will clean out the residue. Once this is done, fill the iron with water, add a couple of drops of lemon juice and you'll be good to go. I know this to be fact...just did it myself : )
Jun 16, 2010 | Rowenta DE851 Iron
4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
Aug 04, 2009 | Sunbeam Irons
Steam iron residue on suit pants
I would send them to the drycleaners and point out the contamination. If they were mine, I would treat them with a little white vinegar; the white deposits are caused by a buildup of calcium in your iron. Don't put the vinegar directly on the trousers but use a clean cloth with some vinegar on it and gently massage the deposits.
It may stink, but it is wise to now and then run it warm (only) with some white vinegar which will dissolve the deposits. Put it on a heat-proof surface (such as a stove grate) so it can stand flat otherwise not all of the deposits will get soaked with vinegar. After letting it soak warm, run several tanksful of plain water to remove the vinegar and shake it over the sink in case there is chunks (very well could be) that have been loosened.
Mar 27, 2009 | Rowenta DG-980 Iron
Dec 22, 2008 | Panasonic NI-R73NR Iron
Rowenta Effective
The rust spot are probably caused by iron in your tap water. I would suggest you put a solution of half vinegar and half water into the water chamber and leave in the iron overnight.
Then switch it on to steam and holding the iron over the sink or over an old towel, the dirt (residue) comes out of the holes on the soleplate. Sometimes if the iron is badly scaled you might need to repeat the descaling.
Once complete, fill again with clean water and steam away, to flush any of the remaining vinegar out of the iron.
Depending on how often you use your iron and how much iron is in your water, you might consider performing this flush process every 2 or 3 months. It will help extend the life of your iron.
Another option is to use distilled water in your iron. Distilled water has all the minerals removed.
Good Luck!
Aug 11, 2008 | Rowenta Powerglide DM273 Iron
Panasonic NI-R73NR Iron Logo
1,224 people viewed this question
Top Panasonic Irons Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
Bill Boyd
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
