Question about TruTech PLV16320 Television
Cannot turn on tv to program a universal remote
The power button on tv does not work so i cannot program a universal remote what do I do??
  • peachykeen43 Dec 23, 2008
    The power button is broken on the inside so I cannot push it on we even took it apart but my problem is that the directions on the universal remote say to manually turn on tv then program the remote..
    Novelist:
  • 152 Answers
Hello, i read some other troubleshooting request and other people had this same issue with there tv not turning on it is a defective
internal board circut fualt.
these are deawood codes they make trutech products
10451, 11661, 10092, 10672, 10623
see if one of these codes works if not do a online search for your tv model remote control codes and try putting them into your universal remote.
hope this helps
Posted on Dec 22, 2008
Need code to program audiosonic universal remote to dick smith tv
Give this a go
1 turn on the tv you want to program to work with the remote control. hold the remote in a straight line in front of your tv at a distance of less than 1 metre.
2 press and hold down the remote device mode button (tv) and the (power) button at the same time until the red light indicator lights constantly.
3 press the power button
4 the (tv) button will blink continuously in red meaning that the remote is searching for the code of your tv.
5 when the remote finds your tv code the tv will turn off.
attention: when the tv turns off you must immediately press the (ok) button to avoid the remote to go to the next code.
6 by pressing the (ok) button you have already stored the code. the (tv) button light will turn off.
Feb 05, 2017 | Universal Televison & Video
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Lost the remote to my philips HTL2101A and it has no power button, so i can't use a programmable remote.
It should still be possible to use a universal remote to power on your TV.
Some universal remote instructions will say that the device has to be turned on in order to properly program the remote. This is not necessarily true, and you should still be able to use the universal remote to find a preset that will at least turn your TV on so you can then follow the instructions for the remote to find the exact preset that will work with every button on the remote.
First, look in the instruction booklet of the universal remote for the section of preset codes. It should be a huge list of 3-5 digit numbers with corresponding device names. There should be at least one or several for Philips devices. Find the code that matches your device.
Then, follow the instructions to program in that code. Should be something like: Hold down a certain button until the light on the remote blinks. Enter the code. Press another button to program the remote for that code. Keep in mind every universal remote is different and will have different steps to follow, but all generally work the same way.
At this point you'll want to just try the POWER button on the remote. If your TV turns on it means the code you entered is the correct code, or at least close to the right one. If it's not the exact correct code some of the other buttons won't work or will command your TV to do the wrong thing.
If your TV does not turn on with the first code you tried, you will need to program the remote with on of the other Philips codes. Just follow the same instructions you used to enter the first code and try another one from the list. Try the POWER button with each of the codes used until the TV turns on.
If none of the Philips codes work you will need to follow the universal remote's instructions to cycle through all of the codes (I have had to do this before). There should be another section of instructions that tell you how to do this. Again, try the POWER button for every code until the TV turns on. Once the TV is on, you will want to follow the instructions for the remote as normal to find the exact code preset that will work correctly with your TV.
If all else fails you might want to purchase a remote that is at least newer than the TV you are trying to operate because an older universal remote may not have the correct preset for a newer device.
I hope this helps! Good Luck!
Dec 15, 2015 | Philips HTL2101A/F7 40 Watts Sound Bar
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Trying to program xbox360 universal remote. found
hey christy, to turn the tv on first push the desired device button like tv from the options tv,vcr,dvd etc. and then press the power button on..!!
it should work
Dec 14, 2009 | Microsoft Xbox 360 Universal Media Remote
I have a rcr3273 universal remote. my tv is rca. i had the remote programmed before and somehow it became unprogrammed. i dont have the instructions anymore and i cant get it working
hold down tv button and power button together until the lcd light turns on. then press the play button every 5 seconds until your tv turns off. press reverse every 2 seconds until it turns back on. press stop to save the programming code.
Nov 09, 2009 | RCA Universal Remote Control
RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
phoenixx100@hotmail.com
http://www.angelfire.com/journal/archer/index.html
Oct 12, 2007 | Televison & Video
TruTech PLV16320 Television Logo
154 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
