Question about Panasonic SC-AK300 CD Shelf System
I have a f61 fault code on my sa-ak600 panasonic audio system
After fiew seconds, my system shut down.
The fan do not run so I tried it on a old computer and it work.
excuse me for my english.
Thank you.
    Problem Solver:
  • 5 Answers
Replace IC500 on power circuit board.
The board at the bottom with heat sink.
STK470-090 voltage regulator Sanyo original.
Posted on Nov 08, 2010
5 CD changer, model sa-ak600. What does code f61 indicate?
F61 means that the power amp has something wrong with it.
It could mean the IC501 has failed or that there is something wrong to the power supply to it.
The good news is the service manual is free online. You can get it by simply putting the model number into google and searching for the PDF of it.
Jan 02, 2016 | Panasonic Audio Players & Recorders
Thermal shut down on Gateway 500r
Have you checked whether the CPU fan is working or not
Sep 27, 2008 | Gateway 500GR PC Desktop
Projector shuts OFF after fiew minutes
Check if all fans are running, there can be several of them and if one does not run the projector shuts off.
May 06, 2014 | Projectiondesign F1 SX PLUS Lamp
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
Since your PC is two years old its recommended to check your computers hardware check your cooling fan
specially CPU cooling fan if that fan is broken your pc wont work and be careful turning on your PC again and again will burn the processor
Aug 04, 2011 | Computers & Internet
The fan is continueslly running and computer takes lot of time to start and shut down. and it is heated also .
The operating system is corrupt in your computer. You can try to run disk cleanup, disk defragmentation, and try to install ccleaner in your computer and clean the old files from your computer. That will be a temporary solution for this.
But if you reformat the operating system in your computer, it will work perfect.
May 23, 2011 | HP Presario C700T Notebook
My panasonic sa ht930 volume when you give me presents on the screen and I f6 1 off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 18, 2011 | Panasonic sa-ht930 Home Theater Audio...
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
My panasonic sa-ak600 cd player doesn't switch on. I checked the fuse inside the unit and found which was good. hopefully, someone can figure it out. thanks
I had the same problem. My unit would turn on, display F61, and turn off. I looked at the manual. It said if you see 'F61', check and correct the Speaker Cords connection. If this does not fix the problem, there is a Power Supply problem. Consult the dealer. Hope this helps.
Oct 04, 2010 | Panasonic SC-AK600 CD Shelf System
Panasonic SC-AK300 CD Shelf System Logo
1,320 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
