Question about Hitachi 53UWX10B 53" Rear Projection Television
Convergence I have a 2002 Hitachi 53uwx10ba, its got the blue and yellow shadows. from what I've read for the solutions, it seems that I need to replace the convergence ICs. I wanted a second opinion on the correct part to use. I think the original part is stk392-110 and I was told I could use stk394-160. Is this true? There's a kit I can get online but I want advice first. Thanks, diduni
    Genius:
  • 1,139 Answers
Hello diduni,
Yes you can use them but read this first:
I could not have said it better myself, I keep this around for times like this.
The various IC's have different specs, one important one is the quiescent current. The higher number STKs have a higher quiescent current (+10%) If you replace a STK 392-110 with an STK 392-150 the small value resistors will "smoke" in many cases and have to be changed with different values. The different TV Help blogs are full of people that have put in the "new and improved" ICs then asked what to do now, all the resistors have smoked or the unit will not start. Hitachi has considerable information on the use of these ICs. In all cases they tell you to change the resistors for different values, to allow for the higher idle current. They also include information regarding alignment for minimum idle current in the circuit. This relates to height, width and hor/vert centre.
The design of the TVs is ok, the IC's fail from AC power bumps or lightning (accumulated damage to junctions over time). Semiconductors will run forever if they have a smooth DC power source, are ventilated to operate within temperature specs, and not overdriven. This was demonstrated when com satelites were first used. They had estimated electronic failure in 4 to 6 years and many last 20+ years. They are replaced when they run out of manouvering fuel or get an induced power surge from the sun. When the IC's run too "hot". there is usually a low ohm resistor that has increased in value and causes higher current output from the chip through the feedback in the circuit design. The resistor(s) may have changed from 1.8 ohms to 2.5 ohms, the TV will still run, but the IC will fail prematurely.
STK 392-110 will work fine if all the small value resistors are ok and the TV is not subjected to a hotter environment than normal or power line related troubles. Many RPTVs are mounted in enclosed areas with no air circulations or in direct sunlight. These situations will cause the unit to operate at raised air temperature around the IC's resulting in more failures. Some people have "hotter" houses than others, their convergence IC's will fail sooner.
If you can redesign the convergence circuits and waste your time replacing all the low ohms resistors, go for it. Otherwise use the STK 392-110, or whatever the manufacturer had in the unit. I know from experience. When Hitachi came out with "new and improved" replacement ICs we installed many STK 392-120 for STK392-110 in Hitachi and other makes. The result was many burnt resistors, many call backs and big expense. The same applies to the Samsung STK392-010 or STK392-040. Use the original IC.
This was borrowed from:
http://www.techlore.com/forum/thread/22290/Rear-projection-TV-STK-392-120-LG-convergence-problem/
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 23, 2008
Hitachi 53uwx10ba "Ghosting" blurring issue
Let me post a few photos and you let me know if they show something like your problem.
I suspect from your description you have a convergence problem.
If I am right rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UWX10BA HDTV with convergence problem for blue
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, a color won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills.
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Blue&yellow double lines on hitachi 53uwx10ba
Electronix Online - Electronic Parts & Accessories for Technicians and Hobbyists
Order Number: 35987
Detailed Invoice: http://www.electronix.com/catalog/account_history_info.php?order_id=35987
Date Ordered: Monday 09 October, 2006
Ordered from IP Address: 65.33.214.137
Technical forum on website had link for Hitachi HDTV convergence board problems
Products
2 x Semiconductor STK392-110 (STK392-110) = $11.98
Sub-Total: $11.98
Tax: $0.00
Shipping: $6.30 via USPS priority Mail 1 X 0.7
Total: $18.28
Sits on soldier stand, and will take a good soldiering job to attach. I replaced both since they are only $12 for two of the STK chips.
Sep 09, 2008 | Hitachi 53UDX10B 53" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blue Shadowing
Yes it sounds like convergence ic's
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 29, 2008 | Hitachi 50UX57B 50" Rear Projection...
Green lines along top of Hitachi 53UWX10BA
convergence ic bad
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hit 53UWX10BA
convergance ic bad
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Problem in Hitachi 43" tv
Common failure called convergence mis-alignment.Needs
convergence IC's replaced by skilled technician.Good set
to keep going a few more years.............T.
Please rate this solution...................
Nov 15, 2007 | Hitachi 43FDX01B TV
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
217 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
