Question about M-Audio Studiophile BX8 Main / Stereo Speaker
Hello, I need a quick problem solved. What cables do I need to hook up the m audio bx8 speakers to my laptop for best output results
Xlr or trs. buy a recording level usb or firewire card with trs or xlr outputs and go with it.
Posted on Jan 23, 2009
HOOK UP 4000456 TO PC
Hello there.
From the little information on this item......
It seems it comes with an audio cable with 3.5mm Jack that plugs in to the headphone or output socket of your PC laptop etc.So that music from your device gets out to the speaker The cable also has a usb plug to plug in your PC to provide power to charge the battery.
If you want to download the guide showing the speaker / cable go here.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4000456_PM_EN.pdf
Sep 21, 2014 | Audio Players & Recorders
How to take the big speaker out of a studiophile BX8 speaker
As you can see, there are 8 screws holding the woofer in. Remove them, lift the speaker up, but before you disconnect it....Mark + and - onto the wires...red + and black -. .http://i46.tinypic.com/14l3j0z.jpg
Aug 18, 2014 | M-Audio Studiophile BX8 Main / Stereo...
Cracklin/popping with m audio bx8 d2's thru fast tack mk2
Check for flucuations in your power supply. If none then put a shield sleeve on your cord.
May 03, 2012 | Avid M-Audio BX8 D2
M audio bx8 blows a fuse
best solution wrap the blown fuse with a piece of tin foil and put it back into the fuse terminal and you shouldn't have a problem.
Mar 03, 2012 | M-Audio Studiophile BX8 Main / Stereo...
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
Purchased used m audio w/o connect cables for cpu
The BX8's take either a TRS or XLR inputs only. from a laptop, you can get a 1/8" stereo to 1/4" l/r mono splitter cable at radio shack that will plug into the back. then just plug up and you will be good to go for about $10.
serously, though, you should save up and buy a studio level firewire or usb card like the presonus inspire and use that to connect. for 200 bucks more spent, you would have much better quality recordings and playbacks that are matched and line level.
BOO-YA!!!
Dec 22, 2008 | M-Audio Studiophile BX8 Main / Stereo...
Humming BX8
Hello docjgg,
This sounds like it may be a loose connection (ground) generation common mode noise or it may be a capacitor in the power supply going bad and not providing enough filtering of the AC voltage (allowing for 60 cycle hum). You should get a schematic for the speaker or just take some rule of thumb measurements of the power supply output, with an oscilloscope (you will be looking for ripple voltage, what you could do is use one of your good speakers as a comparison of good to bad.
If you do not want to work on this yourself, you could take the speaker to any TV repair shop or audio repair shop.
I hope this helps
Thank you,
Shuttle83
May 25, 2008 | M-Audio Studiophile BX8a Speaker
Hook up pair Bx8a to pc
XLR? not true. gold plated, balanced trs cables have a better sound and actually compliments the bx8's technology. that said, you can get cable that is trs-balanced on one end and rca's on the other. then just get a "Y" right-left rca into a stereo 1.5 cable. easy and cheap. but using xlr's for output? NO. save those for your input MIDI instruments and controllers.
Dec 28, 2007 | M-Audio Studiophile BX8a Speaker
Bx8 monitors problems
You will need to REPLACE THE WOOFER / DRIVER on this unit. Cost for a new driver is about $80.
- DJPA
Nov 04, 2007 | M-Audio Studiophile BX8 Main / Stereo...
Subwoffer how to connect it to my amp
You have the M-Audio BX8A speaker listed here. Is this what you have? If so, this is a powered speaker and therefor no need for an amplifier. If you want to use it as part of your 5.1 home theater system, it is not possible to power other speakers with this particular speaker, as it does not have the required output connections.
Jul 23, 2007 | M-Audio Studiophile BX8 Main / Stereo...
M-Audio Studiophile BX8 Main / Stereo Speaker Logo
177 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
