Question about SimpleTech (STI-U2F36/400-BUN) (STIU2F36400BUN) Hard Drive
I first you my simpletech hd on my macbook. then i used it on a pc. now it wont show up on either one. the pc knows that a usb hd is connected but it wont show up in "computer" so i cant do anything with it. i want to just use it on my mac but it was last used on a pc and i want to erase it. how do i do that with vista?
gymowner
  • 679 Answers
SOURCE: SImple Tech HD wont show up on vista
Microsoft long ago decided Windows (this is not unique to Vista) could only format a drive with FAT up to a max size of 32Gb - even though FAT anc deal with larger drives - the thinking being that drives of more than 32Gb really should be NTFS as its more efficient. Windows will USE FAT drives od more than 32Gb but you need to format them outside of windows. Utilities such as Partition Magic for example can create larger FAT partitions which Windows will use.
Posted on Dec 22, 2008
SOURCE: How can i get get WD "my book" hd to also work with windows
Some solutions possible:
(Optional: - First split the video in chunks <2GB to make them more compatible with older filesystems and networking technologies)
A) Copy the file over the network (e.g. using Windows Sharing on the Mac, or using File and Printer Sharing on Vista)
B) Try to do it via the MyBook.  This means the Mac must be able to write something and Vista must be able to read it.  You say you've "set up" the MyBook "for my macbook pro".  How did you format it?  What filesystem?  Mac OS Extended (HFS+) with Journaling?  In general, you need to install something on Vista to read the Mac's filesystem format (HFS+), or on the Mac to write a Windows format (probably best to use NTFS).  Examples of software like that are:    (Win) MacDisk <http://www.macdisk.com>, MacDrive <http://www.mediafour.com/products/macdrive>    (Mac) MacFUSE with NTFS-3G <http://macntfs-3g.blogspot.com/>       or Paragon NTFS <http://www.paragon-software.com/home/ntfs-mac/>
B2) If you've formatted the MyBook as FAT32, you're lucky.  Just split the movie file in chunks <2GB, copy them to the MyBook, copy them from the MyBook in Vista and join the chunks again.
(for splitting you can use e.g. HJSplit and its compatibles <http://www.freebyte.com/hjsplit/>) (also check e.g. "NTFS on your Mac two ways" <http://www.tuaw.com/2007/11/19/ntfs-on-your-mac-two-ways/> for an alternative explanation.)
Posted on Apr 11, 2009
evolrocker
  • 3 Answers
SOURCE: simpletech usb drive model 96300-40001-001 Mac OS9 compatibility
If its 9.2 it may be because your mac is usb 1 and your external HDD is usb 2. It will recognize it but sometimes it takes longer to see the drive.
Posted on Sep 24, 2009
  • 20 Answers
SOURCE: Hi, i have an iomega 500 gb external drive, used
If the power LED is on, it points to a problem with either the disk itself or the housing circuit board. I would open the case up to see what sort of hard drive it is (IDE or SATA) and then get as cheap hard drive housing from Maplin or similar to put the disk into.
Posted on Dec 14, 2009
SOURCE: portable hard drive read only on mac
to format the drive so that it works on a mac, it needs to be formatted in FAT32 format rather than NTFS format on the pc. you can download free software called swissknife that lets you do this. make sure you back up everything on the drive before you format it in swissknife other wise all your data will be lost
Posted on Jan 18, 2010
Can I download Simpletech pininfarina 320gb drivers on Macbook Air
On a Mac you generally have all the drivers you need built in. Would be very rare these days to download a special driver. Any drive plugged in to the USB port usually shows up.
Perhaps the drive needs formatting first. Often external drives are pre formatted for PC.
First...Open Drive Utility in Applications / Utilities Folder
Then Plug External Drive in.
It should show up in Left Column of DU Window
Use Drive Utility to format & test the drive.
Use the Mac OS Extended (Journled) if using with Mac files or FAT 32 if swapping data from PC to Mac & back.
Good Luck
Oct 18, 2014 | SimpleTech Computers & Internet
How to get the software that came with my simpletech simple drive startup disc came with
That software is just there to put up an icon and name of the drive etc it is not important Your drive shows up in in Windows Explorer as a new drive letter If it is not showing you may need to download a mass storage driver.
Nov 20, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
Does the simpletech pinin furina design 32gb operate with a Macbook?
Yes, you can use the SimpleTech Pinafarina drive with your Macbook, you will need to format it for use first. Make sure you have all your data backed up as formatting will destroy your data. First, connect the drive to your Macbook and turn it on. Then open Disk Utility, you can find this by going to the Applications folder, then open the Utilities folder. Locate the drive on the left of the window, then choose the Partition Tab. Choose 1 partition where it says Current, then click on the Option button and change the partition map to GUID, click OK. Then choose Mac OS Extended (Journaled) under the format dropdown menu. Click apply and OK and your drive will format for the Mac. The drive should now appear on your desktop ready to use.
Sep 13, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Hi! I have a 250GB Simpletech pininfarina. I stored my PC stuff on the drive, but would like to now store information from my MAC. What do I need to do to get this working with my MacBook Pro? Jeffrey
hi balkanhope
Save information on a separate hd and wait for folowing operations to be successfull : format your Pininfarina in FAT 32 . Copy data back to Pininfarina . Connect Pininfarina to Mac and proceed further on .
Best regards ,
fanaudi .
Aug 18, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
I had my HD partitioned. It didn't need to be connected to a power source because of the 2.0 USB. Now i've been having speed troubles, as i work a lot with video. I have a mac book pro 2.33 ghz (not the...
The USB 2.0 interface transmits data over *TEN* times as fast as the USB 1.1 interface. So, be sure to connect the USB 2.0 connector to a USB 2.0 port on your Macbook.
Sep 17, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a macbook pro and im trying to backup using a simple tech 160g hard drive but its not showing up
if u have got 2 usb ports try connecting both of the ports simulateously as sometimes power from just 1 USB port is not enough for the HDD.
Sep 12, 2009 | SimpleTech Signature Mini 160GB External...
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
My computer doesen't recognize the hard drive
you need to partition the drive in the first instance before it will do anything, ( as they are not initially partitioned) you need to go into logical drive management to partition the drive. (right click on my computer, select Manage then when the mangement screen comes up select logical drive manager, you should then be able to see your unpartitioned drive which you should then be able to partition and format)
Sep 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Issue connecting HD Video Camcorder HV10 to MacBook
The USB cable is only for downloading still pictures from the camcorder. I don't know of any way to download movie unless you have a computer with the necessary IEE1394 (DV) terminal. Sucks as I have a Macbook Pro and can't download the video!
Jul 14, 2008 | Canon HV10 HD Camcorder
Why wont it work?
doesn't seem that "Simple" if you ask me. I don't think PC hard disks are compatible with Mac's. you might have to get a Mac compatible External HD.
Apr 25, 2008 | SimpleTech SimpleDrive 160 GB External USB...
SimpleTech (STI-U2F36/400-BUN) (STIU2F36400BUN) Hard Drive Logo
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
