Compaq nc6000 Windows could not start because the following file is missing or corrupt: System32\DRIVERS\pci.sys and it didn't come with a startup disk
  • juscruzin2 Dec 23, 2008
    Will try switching the hard drive to another machine. I tried booting in safe mode and get the same error. All I've been able to do is get to a dos prompt and then it can't find hardly any files. Doesn't look good. Thanks for the suggestions.
  • 345 Answers
The error you are having is almost always caused by a hard drive that is bad or going bad. If you have another computer, put the hard drive out of the bad computer into the good computer and run test on the bad hard drive. If after you get the hard drive in the good computer, click on MY COMPUTER and then right click on properties and then click on the TOOLS tab. The first button under the tools tab is error-checking. Run this on the hard drive that is giving you trouble. Be aware this might take a long time (hours). If the computer runs this test all night and you wake up the next morning and it is still running, the hard drive is most likely very bad and has no chance of being repaired.
Much good luck!
Posted on Dec 22, 2008
  • 4,806 Answers
Try to boot into safe mode and perform a system restore
kind regards
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
The following file is missing or corrupt system32\DRIVERS\pci.sys
Windows system files have become corrupted. You can try to Repair your Windows or re-install a fresh copy using the Windows installation CD (for Repair choose R when prompted).
Jan 24, 2011 | Dell Inspiron E1505 Notebook
Ntfs is missing
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
Windows could not start becuase the following file
The answer is in the question Mary.
More specifically the steps here might help:
http://support.microsoft.com/kb/319136
Jul 20, 2010 | HP Compaq nc6220 Notebook
Windows won't start
When you put in the XP CD and it boots off the cd, the XP setup files copy across, and at the 1st screen, you should be able to choose Repair. Press r, and this will start the Recovery Console.
When you are in the recovery console, choose your Windows installation (You will see what I mean when you follow the instructions.)
When you are sitting at the command line(C:\>Windows), access your CDROM drive by typing the letter followed by a colon, eg "D:". It may also be E:, F:, or G:.
When you have changed to the CDROM drive, type the following:
cd\ <enter>
cd\i386 <enter>
expand pci.sy_ C:\pci.sys <enter>
C: <enter>
cd\ <enter>
copy pci.sys C:\windows\system32\drivers <enter>
If it asks to replace, confirm.
Then restart the computer.
Regards
Riztech
Jul 17, 2010 | HP Compaq Presario SR1538X (PX799AA) PC...
How to solve pci.sys error during reformating of the hard drive
You have two ways to solve the problem of "Pci.sys Is Missing or Corrupt"
Error Message When You Start Windows.
1.Booting with WinXP CD to access the Recovery Console’s Repair option,
and then copy from WinXP CD the missing or damaged Pci.sys file to
Systemdrive:\Windows\System32\drivers folder , Exit and Reboot.
start the recovery console and type:
set AllowAllPaths = true
expand d:\i386\pci.sy_ c:\windows\system\drivers32 /y
If you don't type
set AllowAllPaths = true you can't access the windows folder.
2. Booting with WinXP CD and then perform a Windows XP Repair Reinstall
of the currently installed system.
If you need detailed assistance post with details of your Operating system
[WinXP Home vs WinXP Pro and the SP status i.e SP1 or SP2 ]
See
http://support.microsoft.com/default.aspx?scid=319136
Jan 12, 2010 | Microsoft Windows XP Home Edition
System32/DRIVERS/pci.sys
ITS EASY JUST COPY THE FILE pci.sys from any other computer from System32/DRIVERS/pci.sys .SOUNDS FUN?BUT I KNOW IT WORKS
Mar 27, 2009 | Computers & Internet
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
Computers & Internet Logo
128 people viewed this question
Alun Cox
David Payne
David Payne
