Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
I would like to change the image of my external display
I don't how to the to get the image to change. can you please help me.
    Brigadier General:
  • 7,752 Answers
Menu/gallery or meadia,select pictures or the pic you want then click select and make it your wallpaper or screensaver
Posted on Dec 26, 2008
Have power but no Display
Bonnin, Can you see a faint image on the screen? Have you tried to hookup an external monitor?
IF you can see a faint image on the screen, and a normal image on the external monitor, you have a bad power inverter (for the lcd screen) or a bad back light (in the lcd screen).
Take laptop to a shop to have them verify.
Hope this helps.
Nov 24, 2013 | MSI Computers & Internet
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
When I turn on my HP Pavilion 1x1000 It stays on ,but there is no image on the screen, and stays on please help.
A) Post THE Product Number on the bottom of the laptop. It's in the white Service Tag. P/N = Product Number.
B) On the left/bottom side of the LCD screen frame (Display Bezel), there is a switch. Looks like a small button.
This is the Internal Display Switch. (May not be in this exact position for your model. Look around on the Display Bezel, that surrounds the LCD screen)
When the laptop is closed, the switch turns off the display, (Image on screen), with the computer still on.
Tap it a couple of times lightly, with the eraser on the end of a number 2 pencil.
See if anything happens. That switch may be bad.
C) Laptop off, monitor off, connect a VGA monitor to the VGA port on the laptop.
Example of a VGA cable, and VGA connector, (Port),
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
C) Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options,
1) Internal monitor of laptop ONLY
2) Internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the same time tap once on the Display Toggle-Over key.
Don't know what exact HP laptop you have. For most HP's it is the F2 key, or the F4 key, that is the Display Toggle-Over key.
(Key has an empty rectangle on it, with a vertical line on each side)
Still no display on the external VGA monitor?
Hold the Fn key down again. (Bottom left of Keyboard)
Tap once more on the Display Toggle-Over key
NO display on the external VGA monitor, means you have a bad graphics chipset.
(By using an external VGA monitor, you are bypassing the Internal Display Switch, and the Display Assembly. (Internal monitor of laptop)
If you have a display on the external VGA monitor, you have a problem with;
1) Video Cable, (Display Panel Cable for HP)
or
2) Display Assembly
Post back with your results, and if you have a display on the external VGA monitor, we will go on.
If you do not have a display on the external VGA monitor, you are looking at motherboard replacement.
Post back in a Comment.
Regards,
joecoolvette
May 13, 2012 | HP Computers & Internet
I HAVE A DELL INSPIRON M501R, IT FAILS TO CONNECT TO EXTERNAL DISPLAYS LIKE PROJECTORS
Hi
You don't say which operating system you are using.
You don't describe what steps you have tried.
Therefore, the advice I give can only be general, rather than the specific advice I might be able to give if I had more background information.
To send the screen image from the laptop to an External LCD TV, Desktop PC Monitor or a Projector with a VGA or HDMI Cable:
Connect the cable to both devices > power up the laptop > simultaneously press the Fn key + a function key with the picture of 2 monitors (usually F5, F6 or F7) after the computer has booted into the Operating System's desktop and settled down.
I hope this helps.
If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Sep 02, 2011 | Computers & Internet
Image is blurred then goes off
Please connect a external display to this notebook and verify if the external display works fine. If the external display works fine, the you need to replace the display as it is defective.
Thanks and Regards,
Dr. Tony
Jul 23, 2011 | Computers & Internet
Is there any way to adjust the screen image size? I recently connected a computer to the DVI input, and at 1280x720 there is quite a bit of overscan. Is it possible to reduce the image size?
Change the display settings on the computer desktop, try various sizes.
If using programs like word or firefox change display size with shift/mousewheel. Also change font sizes for best view. Don''t worry about resolution numbers, adjust for good picture.
Mar 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Dell d600 will not transfer laptop screen image to nec projector
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and external DVI monitor simultaneously, and external DVI monitor only. HOpe this helps
Oct 22, 2009 | NEC VT460 Multimedia Projector
Hp pavilion ze5500 display monitor still doesn't work
IT could be a motherboard problem with the function key that controls the switching of the video infomation between the LCD screen and the external video connector.
It could be the function key circuitry on the motherboard that controls the back lighting levels on the LCD.
Jan 31, 2009 | HP Pavilion dv6000z Notebook
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
