Question about Kodak EasyShare C613 Digital Camera
I need to transfer pictures held on a PC back onto a SD card in the camera. How can I do it please?
Bought a USB card reader
Posted on Dec 24, 2008
I cannot transfer picture to memory card how?
Connected the camera with the USB cable at pc, open Explorer pc program to view like a "external device", select your files and copy/paste en each folder.
Other way could be using some external device to your SD Card.
Sep 29, 2011 | HP Photosmart 435 Digital Camera
Have "olympus sp 800uz" and
1. Put the SD card into the computers cardreader.
2. Connect the camera through USB with the computer .
3. Copy the pictures.
If you have trouble with the SD card:
1. Copy all the pictures to the computer.
2. Format the sd card in the camera.
3. Copy the pictures back onto the sd card.
Aug 31, 2011 | Olympus SP800UZ Digital Camera
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Problem transferring pictures to PC
    do you have the ability to attempt transfering the pictures onto another computer  maybe its just that computer  what type of card reader are you using  is it factory installed or aftermarket try installing a different card and see it you can transfer pictures from your camera to the computer then  maybe its a file type(format)problem  theres what i have good luck   let me know how it goes
    Mar 28, 2009 | Pentax Optio A10 Digital Camera
    Transfering pictures from camera to card
    The USB connection is the same USB that the Razr cell phone and a lot of others use.
    Jan 16, 2009 | Kodak Easyshare C813 Digital Camera
    Transfering problem
    Your camera has no internal memory so please buy a card reader and transfer your images into your pc and your next memory card
    Oct 15, 2007 | Samsung Digimax L60 Digital Camera
    Lumix® digital camera storage path
    Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
    Aug 31, 2005 | Panasonic Lumix DMC-LC80 Digital Camera
    Kodak EasyShare C613 Digital Camera Logo
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Parshiv Luthra
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
