Question about Philips Nike PSA245 (1 GB) MP3 Player
Problem with philips psa245
Let me run through the story.
About Saturday I repaired the player, removing all songs and data fromit.I then unplugged it for the computer (I can't safe unplug it becausethere is no way to. It isn't recognized as a USB hub by the SafelyRemove Hardware menu) and left it to sync song onto it later.
I reconnected it later, but when I went to sync song onto it, the wholemenu thing came up on Windows media player that finally connects it tothe WMP but it said "cannot connect to windows media player at thistime" and wouldn't let me sync anything onto it.
From that point onward I haven't been able to sync any songs onto it, or even re-format or repair it.
Please Help me, I don't know what to do now. I was with my player inPhilips comis but they tell me that repair will be so dear...
Please send answer message on my email czerstwyburak1@wp.pl
Laura- Poland
  • 8,596 Answers
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
Removing songs from my philips sa30xx
just connect your player to the pc. after the pc recognizes it enter the mycomputer>philips and select the songs you want to delete, right click on them and click delete. or if you want to delete all the songs, then go to mycomputer right click on the device's icon and give format.a window pops up and in that give start. this action deletes all the data in the device
Aug 29, 2009 | Audio Players & Recorders
Problem in data transfer
Make sure the hold/lock switch wasn't accidentally activated
Use Windows Media Player to transfer songs
If the songs you are trying to transfer are in the wrong format (iTunes, for instance), they will still not transfer.
If you use songs that are only in mp3 format, then they should transfer fine using Windows Media Player.
-Tha Mp3 Doctor
Feb 21, 2009 | Philips GOGEAR SA6045 MP3 Player
How to format philips gogear mp3 player?
I wouldn't format it. If you are having problems, run a Repair in Philips Device Manager. If you are getting format errors, then the songs you are trying to load are not compatible with the player - if you download songs that are in true mp3 format, then you will not get any format errors.
-Tha Mp3 Doctor
Jan 25, 2009 | Philips GoGear SA3125/37 MP3 Player
I re-format my Philips go gear mp3.
Run a Repair using the Philips Device Manager that came with the player - or go to Philips website to download the Device Manager.
Jan 11, 2009 | Philips GoGear SA3125/37 MP3 Player
MY philips go gear 2gb music player does not getting on.
Run a Repair in Philips Device Manager - the program came on the installation CD.
If that fails the first time: Unplug the GoGear from the PC. Uninstall all Philips software in the Add/Remove Programs section of Control Panel. Restart your computer and reinstall the software. Replug the GoGear. Re-run the Repair.
-Tha Mp3 Doctor
Dec 27, 2008 | Philips GoGear SA178 MP3 Player
Losing songs on my MP3 player
The songs are in the wrong format. Performa  repair to erase all songs from the mp3 player, and start over from scratch.
Aug 30, 2008 | Philips GoGear SA178 MP3 Player
Philips 8 gb mp3 player
Reset
Run repair in Philips Device Manager
If loading the same song gives you that same error code again, then it's the song - don't use it
Jul 12, 2008 | Philips GOGEAR SA6045 MP3 Player
Static
If you have recently upgraded to Windows Media Player 11, either manually or via Windows Update, this could be the problem.
In this case, uninstall Windows Media Player 11 from Add or Remove Programs, in Control panel.
Also uninstall Windows Media 11 runtime.
This will roll back to Windows Media Player 10.
If you are already using Media Player 10, this problem could also be caused by corrupt firmware on the player.
make sure you have Philips Device Manager installed, from the product CD.
Run Philips Device Manager, and select the restore or repair option, then follow the on-screen prompts.
This will format the player and re-flash the corrupt firmware. All tracks on the player will be deleted.
Reload a few tracks to test.
Mar 06, 2008 | Philips GoGear HDD1830 MP3 Player
8GB GoGear isnt working at all
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Dec 17, 2007 | Philips GoGear HDD1830 MP3 Player
Philips 1630/17 not shown songs on player but from pc seems full
had the same problem just last week on my player. I had to download a newer device manager and then do a repair. also after i did the repair i did a soft reset(hold down the up button for 5 seconds, then push power), now it works fine.
Jul 01, 2007 | Philips HDD1630 MP3 Player
Philips Nike PSA245 (1 GB) MP3 Player Logo
102 people viewed this question
Top Philips Nike Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Philips Nike Audio Player and Recorder Expert? Answer questions, earn points and help others
