Question about Acer Aspire 3000 Notebook
It seems that my laptop want go to ac (adapter) and shuts down
I have an Acer 3000, all of sudden it does not want to run on adapter. Purchased another one and still have the same problems. If I wiggle the adaper cord and hold it tight on the back of the plug that goes in the computer and can some times get a connects then it tells me to switch to adapter (AC) because battery is low. it won't reconize that the ac adapter is plug. Please help someone.
  • cmayeux Dec 22, 2008
    You are probably right because I did notice a crack on the back of the computer where the monitor and keyboard connection (where the hinges are).
    Master:
  • 413 Answers
You need to take it/them back this is something that the factory needs to fix
Posted on Dec 22, 2008
  • 345 Answers
Most likely your problem is caused by a loose connection on the main board of the laptop. Even though it will plug in to the connection, the connection on the mainboard is either cracked or broken. Laptops are VERY hard to work on and you need to find a authorized repair shop for that brand computer in your local area to properly fix this problem.
My Lnovo 3000 G 410 Fan sounding high and pc suddenly shut down
It seems like that your pc is old when you work on it procesdor heats and fans cools but in your case it is overheating your lapy need service open laptop and clear the dust near fan if you are a expert then apply cooling paste on processor head or change the heat sink
Feb 23, 2015 | TechFuel AC Adapter (ACNB90W2130) for...
7720 runs fine off battery ,but will not run off ac adapter ac adapter has been checked and has the right amount of voltage and amps
Adapter: see if you can get a duplicate adapter from someone and try theirs. Your PS has a fault which could lead to damage to the Video portion and down the road, burn out the CPU.
Mar 01, 2014 | Acer Aspire 7720 Notebook
Battery compartment
replace your battery it seems like your laptop has detected a drain higher than normal from battery source of voltage also wants to shut down for battery to charge again and or prevention of ac adapter failing from overheating.
Jul 04, 2013 | Acer Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Battery was running out on my Acer mini book, hibernated and turned of, tried to turn it on nothing happened., used ac adaptor....still nothing
take battery out, unplug ac adapter. Wait one minute. leave battery out. Plug in ac adapter and turn on laptop. Once it turns back on. Shut down laptop and put battery back in. Now you should be able to turn laptop on with or without battery.
Nov 08, 2009 | Acer Aspire One AOA150-1635 Notebook
ACER ASPIRE 3002WLCI
Probably a voltage regulator, they are usually available on ebay, but I suggest having it done at a repair centre.
Jan 28, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
