Question about Aiwa AV-D55
Cannot get the receiver to go off red to green/ from stand-by to on. I plugged it in after i hooked it up and it worked for a few minutes then shut off and now it will not go on again. It just stays in standby.
Do u have a user's manual? Does the clock show when first come on? If does adjust the time then hit enter, and the clock will go off and the system will go off, then u turn back on then is programmed. U can download a manual on www.aiwausa.com.
Posted on Feb 01, 2009
Its a setting that you need to reset
its the power saver feature
Posted on May 08, 2009
Sharp model lcd2a33M,after plug in an power on ,tv on .after few minute power indication on green change to indication red. TV on only few minute
Hey
1) Make sure you are not accidentally pressing the remote control or the Power OFF button is not stuck inwards.
2) If the TV has a key panel (Power Button) on the back cover. Check and see the button is not stuck into.
IF above fails
1) Sounds like a hardware issue. Some signals are not sending the right or receiving the right data. So the protection circuit of the TV has been activated. Please get your manufacturer to come in and give it a good check.
2) If you are able to do "Reset" the TV. It will help. But realize that this might settle the issue or worse it creates unforeseen conditions.
Aug 18, 2015 | Sharp Televison & Video
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
Denon avr-1706 receiver just shuts off
This sounds like the amps protector circuit has been activated due to thermal overload. switch it off for an hour or more to let it cool down, make sure your spkrs are connected properly, don't parallel. Try using a fan on the unit to get that heat away. Get a techie friend to give the insides a once over, and clear away any dust that has built up.
hope this is of some help,
Cheers Kimbo.
Sep 12, 2009 | Denon AVR-1706 Receiver
Onkyo receiver fried after hooking up to pc
I am not used to count colors or numbers on wires, but what you did is that you created an oscillator, by hooking up the output of the receiver and ran it through your computer which inverted the phase, so the thing oscillated and committed suicide. Onkyo used to make some good impact printers, before the modern inkjet came around. If your unit is within warranty, don't hesitate to go where you bought it and ask them to re-imburse you. Receivers don't blow up just like that, because someone hook a wire wrong. One of the specifications is to check just that: phase reversal and oscillations...
My name is Constantin (arzconst is my internal nickname with fixya.com)
Jun 15, 2009 | Onkyo TX-SR606 Receiver
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
After a few minutes the color goes to intense red and green
My tv didn't turn green, but the red separated significantly. It started off happening after a few minutes of being on (I suppose the defective part was "warming up"), then it got to where it was like that immediately upon turning the tv on. In my case, I had to pay a tv repair man $350 for a new part. There are 2 microcircuits that control the color alignment--one that controls the red only, and the other controlls the other 2 colors, blue and green I believe. Maybe your part is the blue/green controller, mine was red. The repair man said these parts fail so rarely they don't stock the part. The cost of repair may be different for a different part, but either way you have to choose if it's worth that cost to you. If you get rid of it, I'll buy your tv stand ;-), I bought mine from a friend and didn't get the stand in the deal.
Dec 14, 2008 | Mitsubishi WT-42315 42" TV
The OSD on my Harman/Kardon 347 does not show up anymore. I am using a Compostie cable and it just stopped working a while ago. I had hooked up an X-Box 360 to my T.V using the 3 RED, GREEN, BLUE component...
Put the receiver in stand by mode (amber light) and hold on the tone button for 8 seconds. This will reset the receiver. After it says reset, let go of the tone button and wait about 30 seconds. Then hit OSD and you should be good to go.
Jul 22, 2008 | Audio Players & Recorders
TV Problem with shutting off by itself
Mine just did the same thing.  Except for it was green instead of blue.  The service manual states 8 flashes from the light stands for an overvoltage.  After reading the manual for a bit I realized the bottom row of 3 adjuster screws from behind the speaker grill adjust the output for the red, green, and blue colors.  BEFORE OPENING ANY TV OR MONITOR PLEASE KNOW THAT THE VOLTAGE INSIDE CAN KILL YOU EVEN IF UN-PLUGGED so please be careful and only adjust what is mentioned here.  I un-plugged the tv, removed the grill and the board covering the internals, and carefully turned the 3 adjustment screws all the way down.  I then waited about 10 minutes (don't know if this made a difference).  I turned on the tv, turned the channel to an auxilary input (for a black screen), and slowly raised each of the 3 bottom screws one by one up clockwise until i could see a faint green, blue, or red line (depending on the screw), and then turned each one back a hair until the screen was black again.  Only adjust one at a time, the order for colors are blue, green, then red from the left.  I hope this fixes your problems.  Be careful when working inside a tv,  I suggest not using a screw driver to adjust the screws due to the possibility of it slipping and someone getting hurt.
Sep 16, 2007 | Sony KP-51WS500 51" Rear Projection...
Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Aug 16, 2007 | Zenith R56W36 56" Rear Projection...
Aiwa AV-D55 Logo
139 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
