Question about JVC GR-DX97 Mini DV Digital Camcorder
Lens Cap Problem
I have a JVC GRDX97-u....when i go to turn on the camcorder and take off the lens cap, the lens still thinks the lense cap is on. I can record but its all black but it picks up the sound. Any suggestions? Thanks
Mine did the same. It was the pickup inside and is a known fault. Mine was over a year out of warranty but the local jvc authorised repairer fixed it under warranty. Didnt even have to show a receipt!
Posted on Apr 24, 2007
I saw something about this on another support board. I think it was on pechorin.com. I can't be sure but it sounded like this is a known issue for JVC and they were extending their service and doing post warrenty fixes.... Might want to check this site and/or contact JVC. Good luck
Posted on Apr 17, 2007
Ys lense cap i it is not
Do you mean no lens cap attached but it shows remove lens cap? If so, most likely your CCD needs replacement. Consult your nearest JVC Service Center
Mar 07, 2010 | JVC GR-D244US Camcorder
Camera seems to think that the lens cap is on, there is no image (and no the lens cap is not on)- jvc mini dv camcorder gr-d347u The message "Lens Cap" appears when the camera is turned on, there is no...
There are 2 possibilities for that symptoms in JVC GR-D347U camcorder is either aparture in lens mechanism is stuck and does not pass image towards CCD Imager OR ccd imager itself got bad.
Qualified camera tech can fix it because it requires expertise.
If you want to fix it, download service manual from HERE for small fee, that will help you how to disassemble/ apart camera and part info etc.
Thanks.
Aug 13, 2009 | JVC GR-D347U Camcorder
It says lens cap when lens cap is removed
KEEP UR HAND CLOSE TO THE LENSES, FACE DETECTION IS ACTIVATED OR U RA MAKING PICTURES OR VIDEOS IN THE NIGHT. TRY WHERE THERE IS LIGHT
Aug 09, 2009 | JVC Everio GZ-MG20 Camcorder
JVC COMPACT VHS CAMCORDER MODEL NO. GR-SXM250U
I cant find a solution but causes may be :
1. Did you remove the LENSE CAP ?
2. PRobably there is a small switch that tells the camera that LENSE CAP is on or something dunno
About that recording problem
1. LCD Broken?
2. Other technical issues ...
Im not proffesional or anything :P Wish you luck with better people at this D: .
Feb 20, 2009 | JVC COMPACT VHS-C CAMCORDER
Lens cap problem
A switch that notifies the camera of the lense cap must be broken?
Camera's Technical stuff must be broken...
Jan 17, 2009 | JVC COMPACT VHS-C CAMCORDER
Lens cap?
Try removing the battery, wait 30 seconds, and plug it back in. That may reset the lens cap sensor.
Aug 11, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Lense cap problem
I too had this problem and as I had taken out an extended warranty I called the store I had purchased the camcorder from. I was told that this model JVC had a problem with the lens cap.They sent it off to JVC who fixed it without question
Jul 19, 2008 | JVC Cybercam GR-DX75 Mini DV Digital...
Dropped camcorder
When you dropped the camera you ended up jamming the iris closed. There may be additional damage within the lens assembly. In order to repair the stuck iris, the optical lens assembly needs to be partially disassembled. This is not a project for the novice. This should be taken to a JVC authorized service center for a repair estimate. The estimate will cost about $50 or so.
Dan
Apr 03, 2008 | JVC Everio GZ-MG57 HDD Camcorder
Lense Cap Error
This problem is caused by a stuck aperture assembly. The problem has occured on multiple models made by JVC (GR-DF430u, GR-DF450U and GR-DF470U). You have to have some degree of technical aptitude in order to disassemble the unit and access the part causing the problem. The tiny motor that opens the aperture flaps is not able to overcome the sticky oil/grease that JVC unwisely used on this part. Therefore the flaps stay closed, and the camera sees no light when you remove the lens cap. This makes the camera think you haven't removed the lens cap, causing the "lens cap" error.
If you feel like you have the skill and you are careful, you can disassemble the unit and clean the part yourself. It takes longer to take the unit apart and put back together than it does to clean the sticky oil off the part.
If you contact me, I can send you a diagram of where the part is located that you need to access. This is not recommended for amateurs, as you can damage the unit and cause other problems if you aren't somewhat skilled in disassembly of electronics.
Mar 03, 2008 | JVC GR-DF450 Mini DV Digital Camcorder
700x digital zoom mini dv - focus problems
Hi, its your ccd sensor. JVC are doing a free repair until June 2008. Visit their website for contact number and more information.
Dec 31, 2007 | JVC Everio GZ-MG37 Camcorder
JVC GR-DX97 Mini DV Digital Camcorder Logo
93 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
