Question about Dometic RM2852 Refrigerator
Dometic RM2852 will not turn on
This refrigerator is installed in my RV. The light on the control panel of the refrigerator will not light, even though the batteries are charged and the 120 VAC is connected. I checked the 12VDC fuse and it is blown. I replaced the fuse and the fuse blew immediately. I checked the 12 VDC input to refregerator with an ohm meter....it read zero ohms. The fuses in the control module in the back of the refrigerator (outside) are not blown. Is there another panel that could be shorted inside the refrigerator on which the buttons are located? Are there electronic components in there also? If there is a circuit board in side the top of the refrigerator, how can I get to it to see what the problem might be? thanks for your help
Gordon Heitlinger
Scottsdale, AZ
  • RVnDon Jan 23, 2009
    Same refrigerator, same problem, no display lights, no interior light and does not run,  EXCEPT, I have no blown fuses.  None at the fuse panel and none in the module at rear.  I do have dc power to the terminal block and ac power at the plug.  What else is there to check?
  • joe_longo200 May 20, 2009
    turned frig off and turned back on check light goes off then back on
The dometic recall requires the installation of a thermal fuse from the DC terminal block to the igniter,  Originally it was a solid wire connection, and the recall replaced this wire with a thermal fuse imbedded.  On my unit the installer placed the fused wire too close to the burner sheet metal and, viola, the fuse blew (being thermal).  Camping World found the problem in 5 minutes and repaired it in another 10 minutes. $107.00.
Posted on Feb 21, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Don't be confused (as I was); there is both a "thermal fuse" and a "thermal switch". The switch has a reset button in the middle of two contacts. The fuse is in-line and covered with a black material to protect it from heat. If the switch has tripped, it will reset when things cool off. If the fuse has blown, nothing works and you have to replace the fuse. (You could wire around it, if you're in the field, but I'm not taking any responsibility if you do so. If you do so, monitor the the fridge furnace to make sure it doesn't overheat.) (My fuse blew when I drove through 116 desert temperatures.)
Posted on Aug 29, 2017
    New Friend:
  • 3 Answers
Dometic has issue a recall kit that includes a new thermal blow fuse which is mounted on the burner tube enclosure. There is also a supplied wire that has a diode inline, if this diode goes bad it will not allow 12v current to flow through and in turn will shut the entire system down. First step is look behind the 6 x 9 sheet of metal to see the thermal fuse. It should be resettable. Push the button between the two terminals. If this does not fix the problem then you will have to have the wire with the diode replaced. If the new recall kit has not been installed then you need to see an authorized repair facility to have that work completed.
Posted on Mar 14, 2013
    Habit-Forming:
  • 20 Answers
Most likely you have either a burned up heating element or a bad circuit board. Check the heating element by unplugging it from the board and checking the two wires, it should read zero ohms, then leave one meter leg on the elements wire and put the other on the actual element you should not have any connection at all (if it does have a connection between it it is shorting to ground which would explain popped fuse). Or you cant just plug the element into direct 110 power and see if it gets hot. If the heating element is good your main circuit board is probably bad the one up top inside almost never goes bad although it is possible.
Fridges between 1993-1996 generally had a problem circuit board. Take the black cover off the circuit board and if it is filled with yellow epoxy it is almost positively the circuit board.
Posted on Feb 20, 2009
Fourwinds hurricane rv
We are Arcticold refrigeration, we manufacture brand new replacement cooling units for Dometic & Norcold RV fridges. Our cooling units all come standard with install instruction, installation hardware, and a lifetime warranty. Feel free to give us a call to free 1-888-782-6665 I can send you the install instructions by email if you would like to take a look at them. In most cases it takes approximately 2 hours to change the cooling unit. I will also need the model number of Refrigerator you have. Visit ArctiCold Refrigeration We keep it cold for some info. Below is a example of one model of cooling unit we build. It is a Dometic RM2852 shown in the picture. 39ede16a-9d21-4648-ad1c-33f0d0c45ff3.jpg 599bd524-a61c-4c24-afa2-1a1a9c84d92c.jpg
Mar 02, 2014 | Dometic Refrigerators
How to install the dometic refrigerator recall parts on my rv
Have it done for free by certified technician. Whichever recall, the labor as well should be covered.
Jun 26, 2010 | Dometic RM2852 Refrigerator
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
Royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Jun 08, 2009 | Dometic RM2852 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Dometic RM2852 Refrigerator Logo
2,301 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Lollo Pop
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
