Question about Honeywell QuietCare HCM-6013i Humidifier
Honeywell 6013i new machine will light up...
But not run.... just out of the box, levelled and filled with water (including filter)....
Help? Ideas? Fixes?
  • rudyamar Jan 11, 2009
    I have the exact same problem. I followed the instructions right out of the box, plugged it in and though the indicators light up, nothing happens. The fan will not turn no matter what the fan speed or humidity settings.
  • Christian Samuelsen
    Christian Samuelsen Feb 19, 2009
    AHA! I figured it out (talked to my dad who opened the box)!! There is a small steel screw that is supposed to be threaded into the top of the water level meter in the base of the unit.
    The FIX: install a 5/8" long screw then put everything back together.
Unplug the machine and take both the water jugs off. Take the motor unit off and flip it over. Plug it into an outlet and press down the small silver contact at the bottom of the motor. When you press this down, a connection is made and the motor should turn on (Don't worry about being electrocuted, this is perfectly safe). If the motor turns on and runs at various fan speeds, you know it's not an issue with the main unit.
When looking at the base, on the left side you'll notice a plastic piece sticking up that's held down with a plastic shroud and 2 screws. This is you water level sensor. When the water level raises up, this also rises and hits the silver contact on the bottom of the motor. Make sure this isn't binding up(I suggest you clean it) I had the same issue with my HMC-6012i, lights were on at the indicated humidity level but the motor would never run. Take the unit apart, clean it out and follow my instructions. It should fire up (Mine is running right now :) )
Posted on Feb 19, 2009
Honeywell he240 no longer working. It is less than 2 months old. I noticed water had stopped flowing out of drain tube. The filter tray is not filling up with water. Humidistat clicks when turned up and...
Maybe the hose is blocked. Take the hose off the supply side, and blow into just enough to add pressure to it and see if that works.
Try this site for more details or a similar issue:
Honeywell HE240 new install not working
Feb 12, 2015 | Honeywell Humidifiers
No humidity
remove and clean the filter then re-install it the air is being blocked
Dec 03, 2013 | Honeywell QuietCare HCM-630 Humidifier
Our HCM-640bw Honeywell humidifier will leak water onto the floor. If I fill the tank and let it sit without turning it on, no leaking. When it runs for about two hours it leaks bad. Any ideas on how to...
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
Jan 18, 2010 | Honeywell QuietCare HCM-630 Humidifier
Honeywell HWM 450
I found a solution to our problem with the fill cap failing/leaking. It was/is not the cap, it’s the gasket/grommet/o-ring. Remember “THE MAGIC BULLET”, well the gasket, that’s where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Dec 31, 2009 | Honeywell HWM-450 4 Gallon Humidifier
Fan works, but no mist and water isn't going away
Turn on furnace and urn up humidistst to call for it. Tube from solenid to the filter should have water running if water is up to the valve and solinoid is opening . It should be warm to your touch., Using an ohm meter you can sheck the coil it shuold have continuity.
Mar 11, 2009 | Honeywell QuietCare HCM-630 Humidifier
Honeywell HCM-305T Spits droplets rather than creating a mist.
Thanks for your question,
Sounds to me like you have something partially cloging the misting nozzle, if you can take the nozzle off, and check it I would bet there is something that got in there, if you cant, it might be better to just return the Humidifier where purchased for an exchange, if you can get the nozzle off, if you have a can of compressed air like they sell for dusting off computers, I would use a very short burst of that in the nozzle, and in the feed line, thanks again for your question, let me know how it works out,
mr.grzz
Jan 14, 2009 | Honeywell HCM-300T Humidifier
Honeywell 6013i new machine will light up but will not work
Unplug the unit (safety first), remove the two water jugs at the back lay them down. Find a tray large enough to fit the motor and filter inside of it put it next to the unit. Lift off the motor and set it next to the tray, lift out the filter and set it into the tray (in might be wet, and we wouldn't want a mess). Look for a small plastic tower in the base, inside that tower is supposed to be a float with a screw threaded into the top. If there is no screw, grab a small one that is about 5/8" long and screw it in about 1/4" put the filter and motor on, verify that the motor is sitting evenly on the base. If it isn't, turn the screw colckwise 1 full turn and recheck the motor/base fit. When it looks even, put the motor back on, plug it in and hope for the best!!
Take your time and don't forget that this is not a precision machine, so some 'adjustments' are necessary
Nov 24, 2008 | Honeywell QuietCare HCM-6013i Humidifier
Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Jan 01, 2008 | Honeywell HCM525 Humidifier
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Honeywell QuietCare HCM-6013i Humidifier Logo
153 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Christian Samuelsen
Christian Samuelsen
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
