Question about Toshiba Satellite A75-S229 Notebook
How to remove Toshiba A75-S229 keyboard
How is this done, removed all screws from bottom, still attached on top, dont know if clips are holding unit or screws. . .
  • 382 Answers
Here is the site I use when I get stuck with repairing Toshibas Good Luck.
http://www.irisvista.com/tech/laptops/ToshibaA75/satA75_1.htm
Posted on Jan 26, 2009
Can not open my toshiba laptop
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
Jun 07, 2012 | Toshiba Satellite A100-S8111TD Notebook
How to take apart my toshiba satellite m55-s135
Have some cups with labels on it to hold all the screws so you will know where they came from. Have a digital camera handy to take pictures.
May 23, 2012 | Toshiba Satellite M55-S135 Notebook
Remove toshiba keyboard
Remove the Power Cord, Remove the Battery. Look inside the battery compartment and see if any screws are there, if so remove them (the keys inside the battery compartment normally holds the strip that is above the keyboard). If you see a screw that has the icon of a keyboard beside it, then that screw holds the keyboard in place. Look along the bottom of the laptop for more screws that have the icon of a keyboard beside them and remove them. In fact you could just remove all screws from the bottom of the laptop just in case you have to remove the palmrest. Remove the screws from the covers that houses the memory and hard drive and check inside them for screws. Sometimes a keyboard screw might be inside them.
Turn the laptop over and remove the strip that is at the top of the keyboard by gently prying it off with a small flat head screw driver. Be careful because there might be a cable attached to it. If the strip above the keyboard is one big piece that requires the whole palmrest to be removed, then look along the sides and top of the keyboard for little catches that you can push to release the keyboard and it will come out without having to remove the palmrest.
if the you have to just remove the strip at the top of the keyboard, once it is removed there might be screws at the top of the keyboard that hide under the strip to remove. Once the screws are removed, gently try to lift the keyboard out. Small catches on the side might be holding it so you might have to work with pulling one side out first then the keyboard will come out. Be careful, there is a cable under the keyboard that plugs into the board. Remove the keyboard cable from the board then lift it all the way out.
May 15, 2012 | Toshiba Satellite M45-S331 Notebook
My dell laptop Inspiron fifteen doesn't type any numbers except 5 or 6. I haven't spilled anything on it ... they just stopped working
have u tryed pulling keyboard out to do that take battery out there are 4 screws remove at the top where the power button is that should clip up gently though, if your battery loads in the front you dont need too remove screw on the bottom too get too your keyboard but on the top of the keyboard after you done that remove key board gently look at your cnnections from the thin ribin see if dirty remove to seperate from the clip its atactched and clean put back together if this dont work buy a new keyboard from ebay..
Apr 10, 2011 | Dell 0Y3740 Keyboard
Toshiba Satellite A75-S229 - how do I change the CMOS Battery?
This is  technical process :
what has to be done is the case to the laptop has to be opened (might be best left to a computer repair shop) to which has many steps to it as in
Keyboard has to be removed
monitor screen has to be disconnected
a large number of screws have to be removed
possibility of Hard drive / ram and a few other devices have to be removed
once opened the battery has to be located to which is about the size of a nickle or quater that has wires connected to it and a small plug at the end of the wires to which connect to the motherboard
simply disconnect and then connect the new battery
now you have to make sure you have the right kind of battery for some laptops take a special battery to which is also totally different from desktops
Hope this helps
Feb 22, 2010 | Toshiba Satellite A75-S229 Notebook
Trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Mar 26, 2009 | ASUS F3SC-B1 Notebook
Removing keyboard
from the unplug the key baord
Dec 09, 2008 | Computers & Internet
Repair
motor coupling broke,,if you can get behind unit,,you will see 2 green clips on the left and the right..if you cant get behind unit take off front acess panel and reach though and remove.slide top forward than disconnect lid switch ,,remove top..theres 2 screws holding front panel on remove..now we can see al lthe washer parts,,please make sure unit is unpluged..remove 2 clips holding pump just grasp and pry up twist and there off ,,remove pump but do not remove hoses..just let pump hang..unplug motor connection ..remove the two screws holding the longer version of the pump clips rmove clips your done replace couping ,,revers to put together careful most of theses parts and cabnit has sharp razor edges,,use gloves
Aug 07, 2008 | Whirlpool LTE5243D Top Load Stacked...
Computers & Internet Logo
312 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
