Question about Belkin USB Parallel Printer Adapter Parallel Adapter
Error Printing to LPTUSB1 for the printer Brother Hl-1230 series
AFter installing the Belkin USB to Parallel printer adapter using Win98 SE, it unstalls LPTUSB ports 1-6 but each one of them I assing to my laser printer retruns the same generic error although the Belkin device shows up as a device under USB Printers under "My Computer", it simply won't communicate. Any suggestions?
  • 39 Answers
Connect the device to a different usb port. Download the newest software/drivers from the Belkin web site. Remove the old software and install the newest downloaded version. Please supply the error.
Posted on Aug 26, 2007
How to install my tvs msp 345 champion printer?
This is a dot matrix printer made by TVS Electronics of India. It used the older parallel port interface (and had an optional serial interface). To hook it up, you'll need a PC with a parallel port, a parallel port cable and drivers. Most PC's no longer have parallel ports, so you'd need to add a parallel port card or use a USB to parallel port adapter. See: http://tvs-msp-printer-driver.blogspot.com/2009/02/download-msp-345-champion-plus-driver.html?m=1
Dec 26, 2014 | Office Equipment & Supplies
Don't know how to connect HL-2040 printer to laptop.
If the printer does not have a USB port and the computer does not have a parallel port then you will need to get a USB to Parallel print adapter. One end is USB to plug into the computer and the other end has a standard parallel port to plug into the printer. Install instructions will come with the adapter. Try any computer shop such as Best Buy, Radio Shack, etc etc.
Apr 24, 2011 | Brother HL-2040 Laser Printer
What kind of cable is needed to connect a Fargo DTC 520 to a computer?
The cable you need for that printer is a Parallel IEEE1284 Compatible Bi-directional printer cable. It is the regular printer cable everyone used before all the printers went USB. If you dont have a parallel port on your computer, the link below is to USB Parallel adapters that you should be able to use with this printer.
USB Parallel Adapters from Tigerdirect.com
I hope this answers your question. Have a great day!
Apr 06, 2011 | Fargo DTC520 Thermal Label Printer
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
XD100 Won't work with USB
check the usb port boot computer and printer..or parallel to usb or usb to parallell try it..
Sep 14, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Printing from a parallel port to a USB printer
Do a Google search for parallel to usb and you should find all kinds of info. It seems that Belkin makes one. Check it out.
Mar 17, 2009 | Xerox Phaser 8550/DT Thermal Printer
Lexmark E210 laser printer driver not working
I had the same problem two years ago and purchased the adaptor also .The port is correct. My adaptor never would work either. The correct answer,for me, was to purchase a Parallel port PCI card and install it.  I am still using it to this day as both the paper and the ink ribbon  on my pin printer is a lot less expensive for making copies that I don't need to be letter perfect.
Feb 17, 2009 | Lexmark E210 Laser Printer
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Belkin USB Parallel Printer Adapter Parallel Adapter Logo
357 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
jason
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
