Question about Reddy HEATER RH125T 125,000-BTU PROFESSIONAL SERIES PREMIUM PORTABLE KEROSENE FORCED AIR HEATER W/TH...
RH125T won't fire
I blew the sawdust off it and thats when it stopped firing. It was just fine till then.
  • 232 Answers
If you blew compressed air into the combustion chamber from the nozzle end of the heater there is a good chance that you broke the ignitor. Check it.
Posted on Dec 26, 2008
89 mitsubishi carby model has spark and pumps fuel to carby but the spark plugs are dry just keeps cranking but wont even try to fire also has good comp,was driving till water pump blew now just wont fire...
Check that the fuel pump is working and pumping fuel (fuse or burnt out) as it sounds like there is no fuel in the carby. To check if the engine is going to run remove the air filter from the top of the carby and pour about a table spoon of fuel directly into the carby throat. Replace the air filter and crank the engine. If is going to run it will fire and then stop
Feb 20, 2013 | Cars & Trucks
I have a Bostitch N60FN air nailer that won't fire, I have replaced tva6 and piston stop, I have no air leaks but when I push trigger I get small puff of air from trigger valve but nothing else.
Easy test, remove the trigger to expose the firing pin and remove the nails. With air connected very quickly depress the firing pin all the way in. If the gun fires, the safey foot is not pushing the pin all the way in. Make adjustments to correct. If the gun still does not fire, the headvalve orings are leaking internally. Remove the head and pull out the head valve. Make sure that there are no fine scratches on the surface where the headvalve orings make contact to cylinder in head. If scratched, remove with very fine sandpaper. Remove the large outer headvalve orings and wind a couple of turns of teflon tape in the groove and replace the oring. This will make the oring fit more snuggly against the head. Lube with white grease and test. Good luck
Dec 28, 2012 | Air Tools & Compressors
1983 944 Porsche drove fine till it started to shake aftermarket radio blew a fuse turn signal wipers turn on by its self ant went really fast the battery plus was touching the hood when I bought it and...
Gonna have to go to the fuse panel first, this is really bad, I have seen a few 944s require a ton of wiring from a short out on the chassis. If the fuses check out then you are going to need to take a multimeter and try getting continuity from some of the switches and sensors. but it looks like the wire going ot the fuel injection could be fried.
Jun 24, 2011 | 1983 Porsche 944
Reddy heater on/off sitch doesnt work, can i jump the wires to test if thats the problem?
Yes, you can, but make sure to use the proper gauge wire. Don't want to start a fire.
Jan 26, 2011 | Reddy Heater RH125T Kerosene Forced Air...
I hooked up an amp for my stereo everything running fine till my fuse blew i put new one in on the main power line from battery to amp stereo works fine but now my valves miss fireing and heads winding bad...
Your amp as nothing to do with your car runnig bad. Your engine has a problem. It's miss fireing may be do to bad coil or even spark plugs or spark wires
Mar 06, 2010 | Honda Accord Cars & Trucks
On lpg vehicle backfires and blows intake pipe to pieces
Hi LPG is very dependent apon plugs and lead quality, the first thing to do is replace them both with new, it may very well cure the fault.
Jan 31, 2009 | 1994 Land Rover Discovery
RH125T won't fire
Not much to check. The element comes out and makes a square loop back to the ceramic portion. This element is extremely brittle and will break if touched or wiped off.
You can check the 2 wires with a voltage tester set on continuity. The needle should swap sides if the ignitor is intact. I don't ever remember an ignitor failing, except for breakage.
View this page. Be sure you get the correct ignitor. 2 different ones have been used on the RH125T.
http://www.reddyparts.com/125T%20ignitors.htm
Dec 28, 2008 | Reddy HEATER RH125T 125,000-BTU...
Heating & Cooling Logo
65 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
