Question about Philips TP3684C 36" TV
Default startup input
When the startup timer is not set, the TV defaults, it seems, to the coax input. I want it to always default to AV1, because that is where my TiVo feeds in and I don't want to change the TV AV mode each time I power up. If the timer is set for AV1, then it seems to set the default to that even for manual power on. Am I missing something?
4 Suggested Answers
  • 81 Answers
SOURCE: Sound does not work in television mode but has white noise in DVD mode
is there a switch on the back of the set?
Posted on Dec 13, 2006
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
  • 9 Answers
SOURCE: Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Posted on Jun 12, 2010
AV1 input question
The TV probably defaults to the RF channels. If it is an analogue only tuner model then it will go to the last used/programmed RF channel.
Sep 04, 2014 | Televison & Video
I have a dvd player drc212 that i have no
Hi Tana,
If your TV is supplied with a video input, you will need a set of Composite Baseband video cables commonly known as RCA cables (Yellow, Red, White).
See the last paragraph if your TV is not supplied with a video input.
You will connect the Yellow (Video) from the DVD's video output, to the Yellow (Video) input on the TV set; example is VIDEO 1 or AV1.
You will connect the Red (Right Audio) from the DVD's Red Audio output, to the Red (Right Audio) input on the TV set using the same input number as example above.
You will connect the White (Left Audio) from the DVD's White Audio output, to the White (Left Audio) input on the TV set using the same input number as example above.
Turn on DVD, and TV set. Select the proper input on the TV set using the input button (video, source, AV select, etc.)
If your TV set is not supplied with a video input only a coax cable input, you will need an RF Modulator which can be purchased at any Best Buy, Radio Shack, Wal-mart, etc. You will also need a small coax jumper (3 to 6 foot should do it), and a set of RCA cables (Yellow, Red, White) as described above. The RF Modulator comes with instructions on how to connect it. It has a coax input, RCA input and a coax output that will connect to your TV set.
I hope this helps. Cheers.
Feb 09, 2010 | Televison & Video
YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
How to make AV1 input the default when switching
Thanks. Problem solved. I found the operating instructions and read them!!
M.J. Ramage
Sep 09, 2009 | Panasonic Televison & Video
Bush TV and Setting Default Inputs
Not an expert on this model but generally if you switch the TV on by pressing the remote's power button it will come back using the input you previously used. If you press a channel button it will come back to DTV.
Jul 19, 2009 | Televison & Video
Default input when turning on the TV
From the menu select Option, then select Input Select, then select the signal type you want to use on startup, set to Auto, then press menu to exit. let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 12, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
I can't work out how to change the default input Sony KV-24WX1U
Don't think it can be done,you'll have to change it manually or it should go to AV1 when you turn on the cable decoder.
Jan 08, 2009 | Televison & Video
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Jan 08, 2009 | RCA F20625 20" TV
No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Oct 16, 2008 | Denon AVR-1602 Receiver
Hi i cant get no sound other than frying inmt rear left and right spearkerall the other is working
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Nov 03, 2007 | Audio Players & Recorders
Philips TP3684C 36" TV Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
