Question about SINGER 7470 Sewing Machine
Singer 7470 jams and buzzes
My singer 7470 keeps jamming on me. I have taken the bobbin out and it still keeps jamming. When I sping the handle in reverse it will work fine. When it goes forward it jams up. I called singer customer support and they have never heard of this problem before. Any suggestions?
  • crsoo Mar 21, 2009
    I have the same problem. I can't get the sewing machine to advance when I sew. The underside gets all knotted up even after I carefully thread it correctly. It was working okay before, but can't get it to sew evenly now.
    Scholar:
  • 35 Answers
To learn how to solve bobbin jam and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
My sewing machine jammed the fabric into the bobbin case and now it won't sew the needle hits the plate under the bobbin case can I adjust this myself
Here are some videos that may help. If not, search the internet for thread jam.
How to Fix Thread Jam Sewing Machine
When Thread is Caught in Sewing Machine Sewing Lessons
https://www.youtube.com/watch?v=tDcBUR0PcyA
If you get it unjammed, be sure to install a new needle as the old one is probably damaged. If there are still issues, the machine's timing may be off and would need professional service.
Oct 23, 2015 | Singer 7470 Confidence Sewing Machine
My singer 7470 i start to sew and clicks and bunches the cotton then the bobbin catches on the hook
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
if these suggestion don't help then the machine needs to be checked to see if it needs some type of adjustments
Mar 19, 2014 | Singer 7470 Computerized Sewing Machine
Sewing machine is jamming on first turn permanently
Your bobbin may be in backwards. Is it possible to put it in either way?
Mar 01, 2014 | Singer Co Singer Talent 3321 Sewing...
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
I have Singer Machine 7470 and when i try to fill the bobbin on top of the machine it make a noise and it wouldn't spin it keep making a noise. Please help
Noisy top bobbin winders is usually caused by no oil on the spindle, or the noise could be coming from a dry top shaft under the balance wheel which is very common
Aug 27, 2011 | SINGER 7470 Sewing Machine
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
Singer simple the machine keeps jaming
I would say that the threading is wrong somewhere, watch your dvd and read the owners manual, also go to Singer.com FAQ for your machine, If the jamming is underneath, it is the top threading problem, on top, it is the bobbin thread either has lint or stray thread or thread not coming out the right direction for your bobbin, I am sure that it is just a simple solution, I also use metal SA 156 bobbins and have no problems,
Apr 05, 2010 | Singer 3116 Simple
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
Bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Apr 02, 2008 | Singer 2662
SINGER 7470 Sewing Machine Logo
422 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
