Question about Gateway FPD1975W 19" LCD Monitor
Monitor red tint not functional.
Red Tint is not functional on my monitor, however when i bring up my monitors menu the icons that have red still have red. So My monitor is still capable of displaying a red tint, but it refuses to do so.
  • Anonymous Jan 08, 2009
    I cannot get red to display. Swapped out monitors.
  • 345 Answers
Unplug the monitor cable from the computer and look into the cable where the metal connector are at. Everytime I've had a problem with one color not showing on the monitor, there has been a bent or flattened pin on the connector. Those pins can be bent out but be VERY carefull, they can break very easily.
Posted on Dec 22, 2008
My hp pavillion dv7 1245dx screen has a red tint in the background?
Your lcd screen is bad. It's either the lcd screen or the video card inside the computer, but most likely the screen. You can isolate the problem by connecting an external monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the read and green tint then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same red and green tint then the video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 05, 2012 | HP Computers & Internet
Red screen on E152fpc monitor
A red or pink tint on LCD monitor indicates that the CFL backlight bulbs are failing. These are just like the florescent bulbs you use at home and the office but much smaller. When they are about the fail they will have a red tint to the light instead of white. They can be replaced but on a 15" LCD its not worth the price and trouble to do it. The bulbs will run about $35 and then about 1 hour to install if you know what you are doing. It would be better for you to get a replacement monitor.
May 07, 2012 | Dell E152FP 15" Flat Panel LCD Monitor
Syncmaster 912n red tint problem
A red or pink tint on LCD monitors indicate that the back light florescent bulbs are about to go out. Just like on regular florescent these bulbs are just much smaller but burn out just the same. Check the date on the back of your monitor, if it is less than 3 years old then its still under warranty but if its not then its time for a new monitor. The bulbs can be replaced but it really is not worth the trouble.
Feb 09, 2012 | Samsung SyncMaster 912N 19" Flat Panel LCD...
I just restored the computer to a month ago hoping I'd get rid of a red tint. It didn't. Now I think it might be a monitor problem. Any suggestions? Earlier this morning , everything had a...
Have you tried replacing the cable first, I had a similar problem with my monitor(only it was blue tint). I would also check and see if the monitors connections are hooked up properly. I hope i could help.
Jun 18, 2011 | AOC 917Sw 19" LCD Monitor
My hp laptop shows a red tint.
bring it back to him but sounds like video card
Apr 28, 2010 | HP Pavilion dv6000z Notebook
The monitor has now got a blue tint I have checked the lead
Your monitor has a menu system that will allow you to access the color guns so you can adjust the red, blue, green guns that create the color picture.
The blue tint may indicate that you need to adjust teh reg and green to offset OR it may indicate that you have lost the red gun all together.
If this is an older monitor and you are considering repair... cost points say it is cheaper to buy a monitor ~$60 bucks
Oct 03, 2009 | Computers & Internet
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
Monitor
Press the menu button on your monitor, then use the controls on the monitor to select something like color balance and turn up the red.
Jul 28, 2009 | Gateway FPD1975W 19" LCD Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
"monitor has a green tint AOpen f2915"
moz-screenshot.png The solution: a hidden menuwithin the main menu itself. Hold the Menu button down while pressing Power topower on, and release power button only when the screen comes up, still holdingthe menu button. The menu will appear and there will now be a hidden selection,"Auto Color", printed in a red-on-black font at the bottom of themenu. Use the +/- buttons to access it, and press Menu. My green/yellow tintwent away! Now my picture works great, and the setting lasts throughAuto-Adjusts and Resets!
May 09, 2009 | AOpen F2913-8S Monitor
Gateway FPD1975W 19" LCD Monitor Logo
279 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
